Old 10-18-2012, 10:05 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
I'll Try Anything
1. Thanks for the guidance.
2. I just got a couple of used 6SN7's, both GE, which I will try tonight.
3. Regarding T3: The Sams numbering is different than the Rider or Wallace Telaides. I assume this is the transformer between the sync amp and horizontal oscillator (Rider T3). I have lifted the 39K resistors, and they check out OK, and the resistance across the coils is also right.
The voltages at V12 pins 2 and 4 don't look right, but I don't know what that means. Even though all the resistors in the horizontal circuit are within 10% tolerance, I'll replace them as David suggests because, if nothing else, I enjoy the soldering.
4. The C35 linking V12a and V12b has been replaced in my model with this chain.
Even though the caps are ceramic, I replaced them just in case.
5. After doing the above, I'll experiment with disconnecting the sync. I say "experiment" because I don't know what to expect--I'll just play with it and see what happens.
Just because Phil mentioned the oscilloscope, I'm showing this photo with the sine wave down the middle--interesting because it's not visible when watching the screen, but is captured with the digital camera. All of this reminds me of the first episode of the original "Outer Limits."
Thanks again,
Winky
