Old 09-15-2012, 01:29 AM
It looks like your horizontal frequency is off, you have multiple pictures side by side.
I don't know if the 17T12 has a fine horiz frequency coil or not, I don't see one on the ETF schematic but if it does adjusting the slug may bring it into range.
If the only horiz frequency control is the horiz hold pot then you may have a component out of spec like a badly drifted resistor or you have put the wrong value cap in the horiz oscillator circuit, i.e a .01 where a .001 should be (done that more than once).
