Old 08-05-2012, 12:35 AM
Zenith H511Y reception problems
I have a Zenith H511-Y "Consol-Tone" (black bakelite cabinet) 5-tube AC-DC radio that works, but not very well. During the day I get only two stations, one a 50kW station 35+ miles away, the other a 1kW local just two miles distant from my apartment. At night, however, I get stations from several Great Lakes states (Ohio [Cleveland, et al], SE Michigan [Detroit], NE Illinois [Chicago], Indiana [Fort Wayne], but not Wisconsin) and up and down the east coast. I have no reception below about 800 kHz. Could this be due to bad capacitors? The antenna connections are good.
The speaker is shot as well (cone is unbelievably torn up -- but, somehow, it still works). The only thing stopping me from replacing it is the fact that the original is 3.2 ohms. Would an eight-ohm speaker work just as well, or would I be running the risk of burning out the output transformer and/or the 50L6 audio output tube with a speaker of higher impedance?
Lastly, I am wondering what the significance is, if any, of the pilot light in my H511 (and all other Zenith radios of its type; Zenith probably made tens of thousands-plus of these sets in the early to mid-1950s, including an AM/SW battery set, the model J402T) other than just as an on-off indicator. The bulb in mine burned out with a brilliant white flash as soon as I turned on the radio for the first time after winning it in an eBay auction (I did not know then, about ten years ago, the importance of recapping old radios before using them). There was no damage that I could see, and the radio worked after the bulb burned out, but I noticed the 35W4 rectifier tube was glowing much brighter than normal. Someone on another antique radio forum (not ARF) told me shortly thereafter the rectifier tube will burn out soon if the radio is operated without the pilot light in the circuit. My question: Is the #47 pilot light in the H511 radios an integral part of the power supply? It must be, if the rectifier tube glows red if the bulb is burned out or is otherwise out of the circuit, but I don't see how, unless the bulb is part of a voltage divider or serves some other function in the B+ power supply.
Thanks much.
Old 08-05-2012, 10:24 AM
Thanks much.
Answer is yes. The pilot lightbulb is wired in parallel with a portion of the 35W4 rectifier heater. Off the hot side of the incoming powerline are connected the pilot light and the 35W4 heater portion mentioned above. Then the pilot light and heater tap in turn connects to the 35W4 rectifier plate. Thru the bulb and heater portion is about 300ma average of current, 150ma for the heater string, and the rest feeds the rectifier and in turn becomes the set's B+. The heater portion will get unhappy with all the 300ma. I think Radio Shack still sells #47 bulbs.
Old 08-05-2012, 12:21 PM
This is all well and good, but I am much more interested in why the radio doesn't pick up more stations than it does in the daytime (as I mentioned, it only gets two stations, and there is no reception below about 800 kHz). I seriously doubt there's anything wrong with the radio if it gets all sorts of stations after sundown, but if this is the case then I would think I'd be hearing every major Cleveland station in daylight hours as well as the two I mentioned (this area has about a dozen AM stations, not counting small low-power ones, one of which went silent about five years ago, in suburbs and small-town "exurbs" which are not considered part of the metropolitan area). I am thinking just about every paper capacitor in my set is bad, since the H511 series was introduced in 1951, sixty-plus years ago.
I also mentioned a Zenith AM-shortwave battery set (farm radio?), 1952 vintage, similar in appearance to the H511. I spent literally hours last night on Google and even eBay looking for information on it (I am interested in this model because of its similarity to the H511), but couldn't find anything. Were these radios any good on shortwave or just so-so? I would think the latter, since the radio was primarily designed for AM broadcast reception.
Also, what types of batteries did this radio use, and where were they stored inside the set? The cabinet doesn't look anywhere nearly big enough for the large 90-volt B battery needed for the plate supply or the smaller batteries needed for the filaments. As large as the H511 cabinet is, it almost certainly isn't big enough for a combo AB battery pack either. The chassis sits on the floor of the cabinet with no space, that I can see anyway, for batteries underneath it. Unless the battery-powered AM-SW version's cabinet is actually larger than that of the line-operated H511s, I cannot imagine where the batteries would be stored. Having a large battery pack sitting alongside the radio wouldn't settle well with most people, unless the batteries were in a separate case that could be hidden under the table on which the radio sits.
Also, the schematic you included with your response is not specifically for the H511. I realize that diagram is for generic 5-tube AM radios (commonly known as AA5s), but is it close enough to the H511 circuit design as to be usable with the latter? I am asking because the H511 has at least one circuit refinement most AA5s do not have -- namely, a tone-compensation network in the audio stage, before the output tube. This probably has no bearing on the configuration of the power supply (when you've seen one AA5 power supply, you've seen them all, except for those weird series-parallel arrangements sometimes found in high-end sets; I have a Zenith MJ1035 with such a filament configuration), but I mention it as a point of interest.
Thanks much.
Old 08-05-2012, 02:27 PM
If you have no reception below 800kHz both day and night, inspect the tuning cap, it may have a slightly bent plate that is shorting out either the antenna coil or the oscillator coil as the plates are meshed. Inspect it closely as you run the tuning up and down. You may be able to hear a scratchy sound as you tune below 800kHz.
Can you patch the speaker? Elmers glue and tea-bag paper works well.
Of course, recap it and replace the #47 bulb! Why even ask?
PS: I suspect that you are looking for info on the Zenith J420T, (J402T does not exist):
http://www.radiomuseum.org/r/zenith_j420t_ch4j60t.html
Is that it?
Old 08-05-2012, 04:51 PM
As jr tech mentions
The cap on the AVC line may be leaky and interfering with the automatic gain function. Just change one wax cap at a time, so you don't forget where its replacement connects to. Change the electrolytic caps too.
Thought comes to mind: check that the antenna circuit doesn't have a broken wire. Though I'd think that the 12BE6 grid would not be biased properly and the set would be deaf.
Though it's way down on my list of suspects today, a weak IF tube or 12BE6 could be the problem. But I always blame wax caps first, just replace them on sight.
Old 08-05-2012, 08:36 PM
Is that it?
Yes, it is. I had forgotten the exact model number and was wondering why I couldn't find it through Google. Thanks much for the correction.
Thanks much as well for the info on possible causes of no reception below 800 kHz on my Zenith H511Y. I took the radio apart this afternoon and looked at the tuning capacitor; yes, there were at least two plates on the tuning cap rotor that were bent out of shape. I rebent them (carefully!), put the chassis back in the cabinet, and fired it up. One of the first stations I received was WJR in Detroit on 760 kHz, which I had heretofore been unable to tune in on this radio because of the short in the tuning capacitor.
The radio now picks up many more than just two stations; since repairing the tuning cap problem, I found I could receive 740kHz (CFZM, Canada), 850kHz (WKNR, Cleveland, ESPN sports), 970kHz (WFUN, Ashtabula, near Lake Erie, also ESPN), 1100 kHz (WTAM, Cleveland, FOX news/talk/sports), and several other local stations besides, to say nothing of the many out-of-state stations I hear on this set after sundown.
I never hear any stations from Florida, Alabama, Mississippi or other areas of the southern US except Georgia on any of my radios, though; I wonder why. (I live in northeastern Ohio near Cleveland.) I believe there is an ESPN sports talk radio station near Tampa which does just that (cuts power back from 50kW to 0.25 kW or less), and drives people close to the towers crazy during the day when they may be hearing the station not only on their radios, but also in their stereo systems between local AMs, through the amplifiers of the stereo phonograph, even on the burner coils on their electric stove if they have one, or on bedsprings! (I've actually heard of this happening in areas extremely close to high-powered AM radio stations, and I personally had a problem similar to this when, in the early 1970s, I lived within one city block of a local FM station, running 27.5 kW ERP, on 92.3 MHz; the signal would come in on just about everything, even a solid-state stereo tape deck and, amazingly, on channel 6 on my Silvertone roundie color TV.) People living near the towers of then-500kW (in the 1930s) WLW-AM radio in Cincinnati had problems like this and worse whenever the station was on the air. Light bulbs would glow even if they were not in sockets or were in unplugged table lamps, fluorescent bulbs would glow and had to be put in closets when not in use .....
What a mess! I bet Cincinnati's farmers breathed a collective sigh of relief when the FCC finally set the present power limit for AM radio stations at 50 kW, and ordered WLW to shut down its 500kW monster for all time. Of course, people living very close to such towers, or even lower-power ones, may still have problems with the extremely strong signal coming in over their stereo phonographs, lighting incandescent bulbs unintentionally, the station coming in on bedsprings or electric stoves, etc.
Amazing what a little bit of judicious bending of a tuning cap plate can do to bring an old radio back to life. This Zenith was an eBay score about ten years ago. I've liked anything and everything Zenith for years, and in fact had an H511Y just like this one in the early 1970s (it was given to me by relatives who were doing major housecleaning). The one I had got lost many years ago; I missed it, so was very glad to find an identical one on eBay in 2002 or so, the year I joined VK (then AK). There is hardly anything to go wrong with sets like this except bad tubes, although I do hope I don't have to replace the 3-section electrolytic in the power supply, since it is a special non-inductive type that cannot be replaced with a standard, off-the-shelf filter capacitor unless a special modification to the chassis is made (this modification is detailed in a note on the schematic). Why Zenith decided to design the H511s with such an oddball type of filter cap is beyond me.
Old 08-05-2012, 11:53 PM
While it may be fun and nostalgic to attempt serious DXing with small vintage analog-dial tube-type table models, I suspect that you need a bit more selectivity and sensitivity than these sets can provide. Have you attempted AM DXing with your ICOM IC-725?... it should be quite a good performer!
Pip, the DX cat says that ICOMS are purrrrrty good!
This station list might be helpful:
http://www.ac6v.com/clearam.php
Happy DXn!
Old 08-06-2012, 01:07 PM
Happy DXn!
My DXing days ended when I moved into an apartment 12 years ago. There is no way I can put up a decent antenna -- for AM, FM, TV, amateur radio or anything else -- in an apartment building (lease restrictions). I cannot use my Icom ham rig anymore for the same reason, so I put it in a box and forgot about it.
BTW, even when I had a decent antenna for HF and broadcast at the house where I used to live, I never heard any AM radio stations from Florida or anyplace else (except the Atlanta, Georgia area) in the southern United States, let alone the Southwest or the West Coast. The closest I ever came to hearing AM radio from the Southwest was when I received a 50kW station from Dallas, and one Sunday night when I heard KOA-AM radio in Denver, the latter after a local Cleveland station had signed off for technical maintenance. I don't remember what radio I heard the Dallas station on, but the Denver station was received on the AM tuner of a Zenith integrated 4-mode stereo system I owned at the time (1980s). Both radios had indoor antennas.
I think my DXing days are over as well because of the noise level in this apartment building. I often hear a loud noise on the AM broadcast band at certain points that sounds like the horizontal oscillator in old (pre-digital) TVs, that masks any stations I may otherwise be able to hear on those frequencies. This building has twelve units, every one of them occupied, so my hands are tied -- I can't tell people not to watch TV just so I can hear a few distant AM radio stations. (They probably wouldn't understand anyway.)
Finally, I realize my DXing problems would be solved if I moved into a house far away from any source of interference, but that too is out of the question (very long story and off-topic).
Old 08-06-2012, 08:21 PM
I must have misunderstood your question... It appears that you have answered it better yourself. If you haven't been able to DX for 12 years, because of your living situation, it appears that it would indeed be very unlikely that you would hear DX stations. Perhaps I am confused?
Old 08-07-2012, 01:56 AM
No, you're not confused -- in fact, that was exactly what I was trying to say, that I can no longer use outdoor antennas for amateur radio and therefore can no longer DX the AM broadcast band, or any other band, as I used to at my previous residence. I miss it, but unfortunately, since I was more or less forced to move from the other house due to circumstances far beyond my control (another OT long story), that's the way it's been the last 12 years -- the closest thing I have to amateur radio HF operation anymore is Echolink, a voice-over-Internet protocol (VoIP) amateur radio linking system developed by a New England amateur 25 years or so ago.
That system is better than nothing, but I still miss my old RF-based ham radio station I had for seventeen years. The only RF-based ham operations open to me anymore from my apartment are FM on 2 meters (I am a member of the local radio club and use their repeater regularly). This repeater is not available, however, on the Echolink system I mentioned; if it were, my problems would be solved, but since the club's membership voted down linking the repeater to the system, I am out of luck as far as that is concerned. The repeater is also having problems receiving signals, probably due to antenna damage from recent violent storms in my area.
I have, however, been able to get to the repeater by moving my 2-meter equipment and antenna (indoor, of necessity) to another location in my apartment. This keeps me in touch with the other club members (through its weekly roundtable on the local repeater), but I have yet another problem -- I cannot get to the club's monthly meetings because I don't drive, and the meetings are held in an area too far away for me to walk to them. There is an amateur operator here in my town, but for some reason he will not have anything to do with me -- even though I haven't insulted him or given him any other reason not to want to associate with me. I even went so far one night, during one of the club's 2-meter roundtable sessions, as to give this person my name, address and telephone number over the air in case he might want to help me out, but I never heard anything from him after that. I then e-mailed the club president, asking if there was any possibility of having one of the members come to my apartment to take me to the meetings and back home afterward; the response was, however, that my club membership does not provide for this kind of assistance. The local public transportation service is no help either because it does not run after about seven o'clock in the evening; our meetings begin at 7:30 and usually do not end until well after ten.
So there you have it. I know this almost sounds like a sob story or seemingly endless complaining but believe me, it's all true. I guess I'll just have to do the best I can with Echolink and my 2-meter FM rig; as I said, these systems are much better than nothing, but still, I wish sometimes I could still use my 100-watt HF rig. I came so close to working all states at my previous residence (49, including Hawaii) and had worked 20+ countries on 20 and 15 meters. I also enjoyed the dickens out of working CW on 30 meters, which I cannot do on Echolink because it does not support that mode -- why, I may never know.
73,
Old 08-07-2012, 10:56 AM
Reece's Avatar
Reece Reece is offline
The noise problem in the building is one thing, but an AA5 can often do amazingly for DX at night if it's tuned up right. If you recap that little Zenith and max tweak the IF's, it should be easily able to pick up WWL New Orleans 870 Kc at night, and WSB Atlanta 750 Kc. Try it near a window and turn it about to aim the loop antenna. If it doesn't have an X type safety cap install one going from the cold side of the power switch to the other side of the line. That will often cut a lot of the noise carried by the power line.
Reece
Old 08-07-2012, 02:24 PM
I looked at the schematic for my H511-Y and found a small capacitor connected between one side of the AC switch and the plate of the 35W4 rectifier tube, which is probably the safety cap you are referring to. I'm sure this cap will need to be replaced along with every other wax capacitor in the radio, as this set is over 60 years old (made in 1951). Probably no wonder I'm getting interference from TV horizontal oscillators and other assorted noises at random spots on the radio dial. The loudspeaker is not in its best shape, either; the cone is torn in several places, but probably salvageable (as suggested to me by another VK member whose name escapes me at the moment). Even at that, the radio still sounds good, but since most AM radio stations these days are talk or news and talk the condition of the speaker doesn't matter much.
BTW:One thing I've been wondering about for the longest time is why Zenith used a special non-inductive type of electrolytic filter capacitor in the H511 series of table radios. If this cap needs to be replaced at any time, Zenith states (on the schematic) that the capacitor must be replaced with the same type as originally found in the radio, or else, if the cap is replaced with a standard one, a special circuit (shown in dashed lines on the diagram) must be installed. I wonder why Zenith chose to use a non-inductive type of electrolytic in these radios, rather than an ordinary, garden-variety 3-section one. What is/was so special about the design of these radios as to require the use of a non-inductive main power supply filter capacitor? I realize the H511 series was one of Zenith's best small table radios in the early to mid 1950s, but to use a special (and likely unavailable except on special order) filter capacitor in the B+ power supply doesn't make a lot of sense to me.
As to tweaking the IF transformers, I'll have to leave those alone since they require a special tuning tool (Zenith 68-19), which is probably no longer available. I couldn't do anything with those transformers even if I had the alignment wrench, since I do not have an RF signal generator.
I am amazed at the simplicity of the circuitry in the H511 series; the schematic takes only one page, at least in the Riders schematic series (the Sams Photofact folder for this set probably has a much larger diagram). This is probably because these are simple 5-tube (AA5) radios with the same basic circuitry as has been used in such radios since they were introduced in the 1940s or '50s.
The only difference I can see in the H511s (commonly known as Zenith's "Consol-Tone" and/or "racetrack" sets and housed in rather large oblong-shaped cabinets) is the tone- and volume-compensation circuits in the audio stage (a hallmark of this series), either between the 1st audio stage and the output tube or between the output tube and the speaker. Some of these radios used a small 3- or 4-lead encapsulated printed circuit component in the audio output to perform the audio shaping task. My H511 doesn't have this part (I've looked high and low in and under the chassis trying to find it), but probably uses discrete components to achieve the same results.
Old 08-07-2012, 03:43 PM
DavGoodlin's Avatar
Motorola Minion
I have a Zenith J615 (one year newer than the H511) with the extra 12BA6 RF amp stage. This makes a difference, especially in the daytime reception. One thing I did was "peak" all the IF can trimmers. I am confined at work to a brick-metal building, a literal "faraday cage , so I had a challenge to optimize daytime reception. This is the best performer in this building to date.
Jeff, if you need the Sams for the alignment procedure, PM me. It may be the last thing (after those caps) you need to do.
The other radio I used to make this daytime reception comparison is a Motorola H56, a typical AA5. I restored it at work "in the cage" over several lunchtimes, and I could barely get more than a few non-local stations after doing the standard alignment.
Now its on loan to a family member as a daily driver for the kitchen.
The Motorola does not have the RF amp stage either, so I imagine your Zenith would be slightly better.
Reece is spot on advise........ get close to a window or at least an outside wall. AM hates tunnels.
Old 08-07-2012, 05:10 PM
Attachment 175739
I don't have many windows in my apartment, and none in the bedroom; the nearest outside wall is in the apartment itself, near the front windows. This apartment building, constructed some time in the 1900s (1911 or 1930; my landlord isn't sure), was originally storefronts which were later converted to apartments (there are 12 units in the building). In fact, my apartment was at one time the landlord's workshop.
A curious thing about radio and TV reception here is that FM reception is great on all but a few stations, but television reception with an antenna (particularly digital) is not as good, which is why almost everyone in the building, myself included, has cable. I do not receive two Cleveland TV stations on VHF DTV channels 8 and 10 (virtual channels 8 and 19) on an indoor antenna -- and don't you know it, the subchannels of those stations (Antenna TV and MeTV, respectively, retro TV channels showing old programs from the 1950s to about the mid-'80s) are the two channels I watch the most. The others (5, 8, 19, 25, 43, 55, 61) come in on an antenna as nice as you please on my flat screen, and I think they look even better now than they ever did in analog.
The Zenith H511 series doesn't have an RF stage. It is just a basic AA5; the only refinements, as I mentioned in my post, are tone-compensation circuits. This series was known as the "Consol-Tone" series because of their rich, full sound from a 5" speaker. Since most AM stations these days do not play music, I guess the high-fidelity feature of these radios is lost -- unless you live in an area that has one or more music stations. One AM music station with a decent signal is CFZM in Toronto on 740 kHz. If you live in the northeastern US or the Great Lakes region, you can probably hear "AM 740" quite well. I live within one mile of the south shore of Lake Erie and can hear the station just about all the time. CFZM also has an Internet audio stream at www.am740.ca if you cannot hear the station OTA.
Old 08-07-2012, 07:51 PM
I've gotten 740 at night as far south as southern Georgia.
