Old 06-08-2012, 12:32 PM
mbear2k mbear2k is offline
Very cool - I'll be following along. What are the model and chassis numbers? I may have documentation and service info I can share.
Old 06-08-2012, 03:03 PM
snelson903 snelson903 is offline
ok got done scrubbing a 1/4 of dirt and who know's what off of the cabnet / bezzell / lower inspection cover, buffed off rust from leg mounts & painted flat black . the inspection cover has some rust in spots ill buff it off and probley paint white .
Old 06-08-2012, 03:18 PM
here is the bezzel after cleaning & before sanding and repainting ,if anyone has a clear picture of the bezzell on this model of what the paint looked like complete please upload a picture here, i probley will not shoot it till saturday .the last picture on the tire is the wrong one thats before cleaning ,theres something kinda going on with uploading pictures to this website. i bought some paint for the bezzel ,close as i can match it without having it mixed for me ,i sanded and cleaned and painted chassie inspection cover .
Old 06-08-2012, 03:25 PM
i will replace the cabnet bottom tonight or saturday its time for some pizza
Old 06-08-2012, 04:12 PM
cool ill uncover some numbers and get them to you, thanks
Old 06-08-2012, 04:40 PM
holmesuser01's Avatar
PIZZA! I WANT!!!!
Is the CRT original? It doesent look like it is laminating, or is my monitor going bad?!?!
Old 06-08-2012, 10:46 PM
yeah it looks like its orginal, dam i was really hoping for a rebuild one ,i removed the strap mounting and wiped some dirt off and it still has the lens on it. i took somemore pic's close up. pizza was good and had me a little nap after to.
Old 06-08-2012, 11:07 PM
I'll look around this weekend, I think I have a spare bezel somewhere with a perfect paint job. If I do, it's yours for postage. I have a control panel too.....or did. Like I said, I'll look in my storage unit for you.
Old 06-08-2012, 11:19 PM
ok ill still sand it down and paint it just to see how it might turn out , got nothing loose at this point.
Old 06-08-2012, 11:24 PM
ok here is pictures of removing bottom of cabnet,and then ill post the clean up of the glue and remainder of o.s.b board. this is kinda fun i never have taken pictures showing what i am doing step by step,wait and see how i remove the guts out of old can capacitors ,it takes about 60 seconds no matter how tough it wants to be.
Old 06-08-2012, 11:28 PM
now prep for new 3/4 plywood im fighting off my cat , he's after my pizza cold pizza if it all goes crazzy that means he stepped on the keyboard i won pizza gone ha ha cat.i think before this is complete i will end up replacing the top to,and if im going to replace the top i might as well do the sides, i got a closer look after cleaning all the dirt off it looks like the top panel is separeting
Old 06-09-2012, 06:25 AM
kvflyer kvflyer is offline
Looks like some car workn' on tools are being used on this TV. You obviously have other hobbies as well! We are a small group of people (I suspect) that appreciate this kind of thing. Looks promising.
Old 06-09-2012, 08:25 AM
yup most of my tools are automotive ,thats what i did or still do depending on the degenerative artheritis in spine allows , worked for olds dealership since i was in high school then owned my own shop for 18yrs in osceola indiana until i got disabled 08 & 09 i brought home everthing and stuff it in my garage and outbuildings ,if notice the chassie in the picture is sitting on a car lift arm that i took home and set up in my garage ,every home needs a car lift in there garage dont they ,sure makes life alittle more easy.
Old 06-09-2012, 08:26 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
I'm impressed!
It's great to see someone take the time to restore an old set like this. All too often they get parted out. Or worse......
Old 06-09-2012, 08:27 AM
im not someone , its me hi--volt lol i cant help it when i see something i cant trough it away , if get rid of something its completly worn out ,then i scrap it if its metal.when i was growing up that's all i ever hurd was the old saying waste not , want not i guess it stuck good in my head .while we are on the subject of never getting rid of things here something i have had since i was a teenager did i mention how much i hate fishtanks ,say hello to my little freind john deer 1010 1949
