Old 06-07-2012, 08:10 AM
marty59's Avatar
marty59 marty59 is offline
I can think of two things right off the bat...You may need to degauss the CRT with a degausing coil (which would not be a bad idea anyways), or the yoke has moved slightly. Untighten the wing nuts and slide the yoke forward and observe. Did it get worse? Now slide it back a bit and see if your blotches dissappear. Hopefully you have a good size mirror to place in front of the set for your observations.
Sometimes you can adjust it for that "sweet spot". If this fails then Purity adjustment may be in order.
