Old 05-28-2012, 12:55 PM
chipper chipper is offline
Antique TV Tuner Repair
Just wanted to know If there was a tech out there that specializes in tuner repair for antique tv's I have 2 tuners that I need rebuilt? thanks, chip
Old 06-02-2012, 10:52 PM
marty59's Avatar
marty59 marty59 is offline
Unless someone has some good "tech tips" for working on tuners, you're about as out of luck as having a CRT rebuilt. Louis Slagle of Quality Tuner Service in Longview, Texas was one of the last I believe. He rebuilt my tuner for my Predicta back in '08 and he was winding down then.
Back in the day just about every major city had a shop or two and now it seems to have turned into a lost art.
Old 06-05-2012, 05:29 PM
Penthode's Avatar
Penthode Penthode is offline
Can you describe the tuners? What is wrong with them?
Old 06-22-2012, 05:14 PM
DavGoodlin's Avatar
Motorola Minion
I used a few places like PTS in the past. The repairs were usually pretty inexpensive, so it can't be that involved.
If you put one of those 7 and 9 pin socket extenders under your tubes, you can measure voltages and resistances. Not much to go wrong, maybe solder connections, feed-thru caps shorted, resistors etc, but to get IN there and actually replace a part, paying strict attention to lead dress could be like watchmaking.
Turret tuners should not be big deal but wafer jobs are hard to get into.
I usually saved good tuners on sets I scrapped, what do you have?
Old 08-14-2012, 06:20 PM
Fuzzy picture
I think I might have open or shorted caps(58 sylvania 21" set) Would like to find a good used or rebuilt replacement tuner?
Old 08-14-2012, 08:37 PM
does it get better if you move the tuner around to find a sweet spot? there can be a lot of things that cause picture problems. Posting a pic would help.
does the fine tuning do anything?
Old 08-15-2012, 10:32 PM
The last time I tried contacting Louis Stangle his business phone had been disconnected. The one time I talked with him he mentioned throwing away a huge pile of old tuners
Seems like last year one of the guys on here talked about someone he knew that still dabbled in them, maybe samson?
Old 08-18-2012, 02:26 PM
Fine tuning
Yes: Fine tuning does help a bit, I think this set was hit by lighting or a surge? I did try to contact that guy that repair's tuners, but had no luck. This set has had a recap and I got a crt from bob.
Old 08-18-2012, 03:33 PM
if thats the case you should check the balun mounted on the tuner. I had a zenith that had a smoked balun. Presented with a lot of snow but a pic was there. At the time I did NOT have a replacement, I took the old one out and rewound the smoke coil. Worked fine after that.
Old 08-20-2012, 01:41 PM
ok; will ck the balun? and try to show a picture?
Old 08-20-2012, 10:53 PM
I seem to remember a tuner repair/rebuild shop called "Castle", back about 35-40 years ago. They were based, IIRC, in Dallas or some place else out west. I don't know if they are still around; they may have gone out of business shortly after the DTV transition.
Old 08-21-2012, 10:24 PM
6GH8cowboy 6GH8cowboy is offline
Tube extenders to trouble shoot a tuner are useless. Throws them way out of tune and most voltages will be useless. Back in the day balluns or a plate resistor were the most fixable things. Anything else off to the tuner shop. $7-$9 plus shipping for most repairs.
