Old 03-20-2012, 07:47 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Motorola 7" question
Hi!
Anybody experience with this?
Does it fit well?
http://www.ebay.com/itm/Motorola-Tel...item35b74014ef
Inputs are welcome.
Many thanks,
TV-Collector
Old 03-20-2012, 10:26 AM
miniman82's Avatar
First Light: 1952-2011
It takes a little work to get it to fit right, but once it's in there it's worth the effort IMO.
Evolution...
Old 03-20-2012, 12:41 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I purchased one of these for a VT-71 I have, but I've not yet installed it. It seemed expensive to me, but one of those final touches that makes the set look all the better when you're done with a restoration.
Old 03-20-2012, 12:59 PM
I've used three of them and they are identical to the originals. It is a tight fit, but looks good once installed.
Old 03-20-2012, 01:06 PM
kx250rider's Avatar
REAL TVs have TUBES!
I bought one too, and haven't yet installed it. Based on the quality and texture of the rubber, it's very accurate-looking, and I see no reason why it wouldn't fit. I think it may arrive a little out-of-shape, but the tube nested into the gasket should straighten it out nicely. If it's noticeably out of shape, I'd put it in the sun for a few hours to soften it up before installing it.
Charles
Old 03-20-2012, 08:15 PM
kvflyer kvflyer is offline
I have bought two of them and have one installed. They are just fine.
Old 03-20-2012, 10:25 PM
I bought one too, it fits well but it's a little tricky to install.
I had to lube the face of the tube (water based gel only) to get it to fit, then you have to tighten the neck clamp while you hold it, two people might make it easier.
This is probably why some of them had Friction Tape on the neck, to keep it from slipping backwards.
Old 03-22-2012, 07:37 AM
Thanks people for the replies!
TV-Collector
Old 03-23-2012, 08:18 AM
"Sorry, item cannot be shipped to Germany"
It was a try.
Happy week-end,
TV-Collector
Old 03-23-2012, 08:54 AM
tubesrule's Avatar
tubesrule tubesrule is offline
It was a try.
Happy week-end,
TV-Collector
I'm the one that got these reproductions made with the help of Chuck A. who loaned us a perfect original one. (yes, at least one perfect original still exists!) Ed S. who runs Renovated Radios is a neighbor of mine and is the guy who reproduces all the knobs and rubber parts. He wanted to know what parts us TV guys would like, and this is the first thing that came to me. He uses an expanding closed cell urethane foam to make these to the original consistency and pliancy. The material cost is fairly high and then he rejects a number of them if they get air bubbles in them. The fit is as the original but it does help to wet the inside edge when installing the crt to ease the positioning of it.
I would try purchasing the mask directly from his web site at : http://www.renovatedradios.com/parts.html
The mask is near the bottom of the page. I believe Ed ships world wide. I would contact him first as the Paypal shipping calculator is usually wrong for international, and rates have gone up here significantly.
Darryl
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 03-23-2012, 09:06 AM
Thanks Darryl!
One more try!
TV-Collector
Old 03-23-2012, 12:41 PM
Darryl
My blond VT-71 still has a decent original CRT gasket so that makes two!
Old 03-23-2012, 01:50 PM
tubesrule's Avatar
That's good to know Tom. The initial problem with reproducing these was I couldn't get Ed a good one. The ones in my sets that appeared fine would not come out. No matter how we tried (heat, solvents, etc) they would shatter into pieces when trying to remove them from the front board. We actually started gluing the pieces of one of them back together so he could at least start making the master, but then Chuck came up with this one that was still pliable and hadn't lost it's shape. I couldn't believe that any had survived and were still pliable. That was a life saver and made these repro's possible.
Darryl
Old 03-23-2012, 08:39 PM
Let me say again that the masks that Ed S. makes are excellent. He went to a lot of work to make the first one. As I mentioned, I have two of them. They certainly do make the VT-71 complete. Maybe one feels that they are expensive, but they do look good when done...
Old 03-23-2012, 10:33 PM
It cost's thousands to get a 15G rebuilt for the CT-100, $43 isn't all that much.
