Old 03-18-2012, 12:40 PM
Originally Posted by charokeeroad View Post
Should I just look for the caps that I know need to be replaced as described in the antiqueradio website?
Yes. Replace the obvious stuff first.
As John (and the article) noted, you can also use the value as a clue whether to replace. For instance, in your second photo, the whitish cap in the middle is marked .02, too big for a mica and too small for an electrolytic -- just right for a paper cap, so get it out of there.
I don't see anything to replace in the second photo. You're doing OK so far. Don't worry about the other components for the time being. The doughnut-ty shaped things may be peaking coils, and so on. You will have time to learn more about other components while waiting for your capacitor order to arrive.
Phil Nelson
