Old 07-13-2011, 04:00 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
In case you don't have the Schematic.
Power Factor should be zero for perfect capacitors. It's an indication of the internal series resistance. It's measured at 60HZ and is the ratio of the real power to apparent power. The current should be 90 degrees out of phase with the voltage for a capacitor. Internal resistance changes that and you start to dissipate real power as the phase shifts from 90 degrees towards zero.
I might have been a little sloppy in my explanation.
