Old 01-16-2011, 04:18 PM
Originally Posted by miniman82 View Post
my RCA data shows the 11 can use either the CYP or FJP tubes, looks like yours has an FJP. That thing is so delaminated, I bet it would just pop right off if you applied some gentle pressure. The ones I've done surgery to only had a little mold on the outermost parts, so they were still a pain to remove. I just break them off piece by piece with a screwdriver, it's back breaking but not nearly as dangerous as the heat method.
Yep, it's a FJP. I just noticed it's a model CTC-11C. If you break them off piece by piece, what do you use for a replacement glass? Sounds dangerous. This set came here from CA late 60's or early 70's, according to the previous owner.
Kevin
