Old 06-01-2010, 10:48 AM
Zenith color yoke
Tried Moyers, no joy, 95-2501
I seem to recall someone saying there was a store in Tampa that carried old yokes. anyone remember that one?
Old 06-01-2010, 03:17 PM
peverett peverett is offline
My computer list indicates that I have one of these. It may be a couple of days before I can confirm. I will post again when I confirm.
Old 06-01-2010, 04:19 PM
I have confirmed that I do have a Zenith box labeled 95-2501 that contains a color yoke. I cannot find a part number on the yoke itself. There is a rectangular connector on the yoke that would connect the yoke to the chassis.
Old 06-01-2010, 04:23 PM
Bad news: I just noticed a label hand written on the box that says "Open Vert", so the yoke may not be good. (The owner of the TV shop that I cleaned out to get this saved everything-good and bad).
Do you have a Sam's number of know what the resistance values for the yoke should be? I can check to verify the open vertical winding.
Old 09-07-2010, 09:48 AM
I am sorry I never got back to you, I must be slipping.
anyway the yoke resistance is vert 13.2 and horz 8.7 per the sams.
and it looks like I may need one, my orig zenith turned out to be ok, but the new one is acting funny and may need a yoke.
Old 09-14-2010, 12:28 AM
I have not gotten around to checking the yoke resistance yet, but hope to do this in the next few days.
Old 09-14-2010, 01:16 AM
thx!
Old 09-16-2010, 07:57 PM
kc8adu's Avatar
kc8adu kc8adu is offline
got the thordarson y- number?
email for more info
Old 09-16-2010, 09:23 PM
thor Y-108
Stan DY-91AC
triad YC-310-2
Old 09-17-2010, 12:30 AM
I took a look at the yoke I have. There are several connections, so it is hard to tell which is vertical and which is horizontal. It seems that the actual coils have 4 connections each. Anyway, one of them looks ok, less than 20 ohms to between all four connections. The other does not, with 437 ohms between two of the four connections and the other two being open.
Old 09-17-2010, 12:49 AM
actually that may be ok, its a confusing yoke plug. there are a couple connections that have two 220 resistors
check
yel/black to yellow 440 ohms
green to yel/black prob 7 ohms
white to yellow prob 7 ohms
green to white prob 460 ohms
Blue to red 8.7 ohms
Blue to ohter red 4.5 ohms
Red to Read 4.5 ohms
whew...
Old 09-17-2010, 01:06 PM
FYI, I no longer think I have a Yoke issue, I was chasing a pin cushion problem that I "thought" was a yoke problem. However, it maybe helpful data about how to check the yokes out.
Old 09-17-2010, 07:04 PM
I will check between the wires anyway and let you know what I find.
Old 09-17-2010, 09:41 PM
yoke wiring and resistance
