Old 08-30-2010, 11:04 PM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Scratching my head a bit to try to recall - later non-Trinitron tubes often had common electrode voltages (except for the cathodes, which got separate RGB drive), but I'm not sure if any had a series of common electrostatic fields for all three beams the way the real Trinitron did.
Of course, only the Trinitron had the tensioned-grill shadow mask (with a cylindrical contour). All the other in-line tubes had a solid shadow mask, with short vertical slots and even shorter cross pieces defining the ends of the slots.
You're right, I do not recall ever seeing any TV sets made around the same time as the late-model Trinitrons that have the vertically flat picture tube. Is a tensioned-grille shadow mask the same thing as an aperture grille?
Sony Trinitron Fan
