I take a small wirecutter and cut off the pins, then i take a small pliers and a strong soldering iron to remove the pins from the pwb. That works good. Before replacing the IPM you have to change the SMD electrolytics under the IPM, els the IPM will fail a short time after replacing again.
Here is a interesting Link (in german) where a guy has rebuild an IPM: http://user.cs.tu-berlin.de/~msaal/P...42SD3_YSUS.pdf Have a nice day. Frank |
