Old 06-10-2010, 12:33 PM
If you get it right, it's a beautiful performer. I have this exact model and love it! The HD looks great and the color is stunning. There is a service menu on these but I don't have the manual yet to see how to access it. I've also been told that if you play with things in that menu without knowing what you're doing, the set can be messed up real bad, even shut down without being able to turn it back on. Be careful if you're in that service mode. The CRT is made in the USA and the rest is made in Mexico for the most part. These can be really hard to troubleshoot, everything is computer controlled, even the convergence. You may end up just changing out a whole board, lot's of SMP's in there. Good luck with it, if you get it right, you'll fall in love with it like I did mine.
What month was it made? The early '04 models had a part that was a problem but I don't remember what it is, I'll see if I can look it up again. The ones made after September had the revised part that stopped the problem. Mine is a December '04 model so I got lucky. Maybe that problematic part is what's wrong with yours. It did cause crazy picture problems and jittering IIRC.
