Old 02-27-2010, 12:58 PM
kx250rider's Avatar
REAL TVs have TUBES!
Here you go! I wish I had better skills & camera to get really good screen shots. Believe me this photo doesn't do it justice.
Charles
Old 02-27-2010, 01:19 PM
I believe you.....
Old 03-02-2010, 04:13 AM
colorfixer's Avatar
Charles,
What is the official use of the grey plastic knob behind the deflection yoke. I have the same one on the PVM I posted about, and the manual quickly eludes to "dynamic purity".
BTW: it was a combo of the yoke positioning and the degauss circuit. Once I pulled the degauss coil, and manually degaussed the thing, redoing the beam landing and fixing the degauss cct put it to bed. There was 30v on the degauss coil even after 20 minutes.
Old 03-02-2010, 11:19 AM
kx250rider's Avatar
Originally Posted by colorfixer View Post
Charles,
Honestly I don't remember exactly, but I can look in the manual. I'm curious now. ON the later Sonys with the gray knob sticking rearward, it's a primary purity setting (to center the red bar in on the screen with the yoke pulled back). Probably the same here, but I'd hesitate to say unless I look it up. That little 330AB22 has electrostatic convergence through a second anode connector on the side of the neck, and it had a different setup procedure than the newer Trinitron tubes. I think the last time I did a setup on a 330AB22 had to be 25 years ago.
Charles
Old 03-02-2010, 11:29 AM
Old 03-02-2010, 12:09 PM
freakaftr8's Avatar
Convergence freak!
Wow Charles, that is an awesome find!! I have the same set, unfortunantly, it's dead as a doornail, and I have to figure it out. But, wow!! Brand spanking new!
Old 03-02-2010, 05:41 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
i have this same set, but in the opposite condition!
Mine is all beat up and has a million hours on it, the phosphors have darkened (burned) so much with use that it looks like a "black trinitron"
Of course it no longer works, it only displays a weak greenish blank raster, but it's so cute i can't get myself to strip it for parts and throw it out.
Old 03-03-2010, 03:26 AM
colorfixer's Avatar
It's amazing what turns up. That's quite possibly a once in a lifetime find Charles.
Old 03-03-2010, 12:59 PM
kx250rider's Avatar
Thanks! I do have a spare KV-1201/1210, which needs the HVR block but is otherwise a good working set, afaik. (CRT unknown), if you need parts. But are you permanently relocated Back East, or are you still in Ventura occasionally?
New in the box sets are extremely rare, and too bad this one was missing the box. It probably was there, but maybe was tattered. All the other Sony stuff this lady was selling, was still sealed in boxes. I got two other sets from her; a 1981 KX-1901, and a 2001-ish 13" Trinitron that she said her Dad kept new because it was the last non-flat Trinitron made. My wife took a liking to it, and it's now her daily kitchen watcher (box carefully kept, of course).
Probably my most exciting new-in-the-box TV I have is a 1948 Motorola VT-71. Sadly, the rubber CRT mask melted anyway, and ruined the gold paint inside the front bezel. I'm not sure yet if I'll replace that, or leave the set virgin with the melted mask.
Charles
Old 03-04-2010, 12:21 AM
freakaftr8's Avatar
Convergence freak!
No im still up here in Folsom, but I might be down in Ventura in the middle of this month sometime, ill keep you posted!! Hey did you ever find a yoke for that Zenith of mine? Im thinking of puttin my nose back into it..
Charles
Old 03-04-2010, 01:15 PM
kx250rider's Avatar
No luck on the yoke yet, but I do still have that jig for you. No rush; just give me a heads up and I'll have that here for you. I think I better have that jig here in Moorpark, as your wife will put a contract out on me if I let you see the sets piled up in that building in Chatsworth where the jig is ... But on the other hand....
Charles
