The MSDS for the replacement coolant says that it is about 75% ethylene glycol and 25% glycerine. I'm not sure there's much besides water that would have worked.
While letting it dry longer might have been prudent, any damage done probably occurred when you turned the set on right after the leak. You could try partsrruss.com for the service info or use google with the the model number and "service manual" as the keywords. John |
