#31
Late '80's Emerson sets were made by Orion. I actually fixed two late '80's emerson's with the side mounted chassis. Both were full of bad solder connections and bad caps in the vertical circuit. I was a little shocked to get two of these in that actually still powered up. I was getting these when they were only a few years old with toasted flybacks, yokes, and shorted HOT's.
#32
I am curious, what makes a bad tv? is it design/assy/parts? esp things like flybacks/crts, are they just poorly designed/overstress/cheap builds.
Seems odd that a process devolves, I have old sets that seem rock solid, it follows that process and procedures should produce better goods (I am not so naive to think that other consideration conspire to reduce quality, just wonder where those consideration hit). |
#33
THIS NEW FLAT SCREEN GARBAGE!! -- I much prefer the classic TV i have always watched and love (And in analogue if possible)
#34
Reading this post sure has brought back some memories. I worked in my Uncles TV sales/service shop in the late 70's early 80's in a small town in Nebraska. We sold Zenith, and for a time he carried a secondary brand as well, so as not to lose a sale to the people who couldn't afford a Zenith. (they were expensive). I remember when the recalls hit the CC2's for the safety cap, and we even had a Zenith that the cap failed and blew out the picture tube. To Zenith's credit they did replace the tube altho the set was out of warranty. We were busy with service calls replacing that cap on every affected set we sold.
For worst sets on our service route a few stand out, and I can still hear him bitch when we had to go out yet again to that service address. 1) RCA CTC-38's were one of the few sets RCA put out where they went "on the cheap" Like clockwork, EVERY summer (once the heat and humidity came up) the calls came in for "no picture and a bad smell" Those sets ate up flybacks like there was no tomorrow. Coupled with color alignment problems (which you never saw on any other RCA chassis) also the majority of 6GH8's that were sure to be bad made that chassis a POS in my opinion, altho it was a money maker from a repair standpoint. 2) Any Motorola. Tube color sets the worst, followed by the solid state "works in a drawer", with the 4 tube hybrid behind, which interestingly followed the solid state set in production. Those sets always were glitchy and had a LOUSY picture. 3) Magnavox tube sets 4) ANY Admiral We also had a Western Auto and Gambles in town, so we got stuck doing a repairs on those. Trutone was the WORST. (Wells Gardner and rebadged GE's). Gambles by the mid to late 70's were mostly rebadged Toshiba Blackstripes. I have a 77 13" Coronado that is one such set. Finally, I remember for a bit my Uncle sold GE sets as a secondary in 80-81. Not sure of the chassis, but they were the sets with the VIR color correction. They were the only set I was aware of that managed to blow up ON the sales floor. IIRC it was a Yoke issue, and they had LOUSY pictures to boot. I'm sure more will come to mind, but the ones I listed seem to stand out the most. |
#35
Charles
Collecting & restoring TVs in Los Angeles since age 10 |
#36
I stand by my vote that the Magnavoxes are worse than the GEs, my portacolors never gave me much trouble even though the picture wasn't that great, one Magnavox I had actually had a flyback catch fire, stunk up my place for days. Then again, I never had a GE console.
Now I'll say something more controversial, while I really think the flat chassis Zeniths are 100% deserving of the reputation they have here, I really don't think the same of the chromacolor II era sets. While I'm not at all nominating them for worst color set, as they do indeed produce a great picture, the two I've had had all these intermittent faults, some were due to bad solder joints, loose connections where the modules plug in, or that stinking chromatic button which always seems to get gummed up. On either set I had I never managed to track all of the minor intermittent issues they had down. Great sets when they work, but they didn't hold up nearly as well over the years as their flat chassis counterparts. Last edited by Adam; 12-05-2009 at 08:54 PM. |
#37
I unfortuanately would have to agree with Adams opinion concerning CC2 era sets. Hard for me to admit as I unpacked and sold those sets when they were new.
When new, there was NOTHING out there that produced a better picture, and they still beat out most sets today after 30+ years, but they have proved to be glitchy once they had some age on them. In all fairness, it was a design flaw that all modular sets of that era seem to have. From a design point, it was to save time and money on repair. If one component failed you simply replaced that module. However most manufactures that went that route all had the same problem once they aged. RCA XL100's with a vertical chassis is just as bad. Zenith has that damn problem with the Chromacolor control. RCA had problems with the slider controls. I always keep a "daily watcher" in my home office. Right now, I have a top of the line System 3. Pretty good performer, but the picture tube is starting to show its age. Those tri-focus tubes didn't hold up like the Chromacolor dot matrix tubes did. My other set I use when I swap out the System 3 is a 75 Chromacolor 2. When that set is in use, I always seem to have to replace a module or 2 to get it working perfectly. In all fairness, it IS 35 years old..... |
#38
those sanyos from the mid 70s.uggggghhh!very nasty little sets.ge,rcas from the 90s,zenith of the same vintage.bad,bad,bad sets.i had a couple of really good wells gardners from the early 70s,(hybrids un the j c penny name).they both had rauland crts and were good performers.one was in a combo that also had a blasting stereo.we could rock the zip code with that monster.solid wood cabinet that i had too move too many times.some of those later sets were junk.i did like the 2 i had.ge s had a nice picture when they were right.those just werent right very long.many stores had name brands that were nightmares too.too many bad ones and not enough good ones to name.
#39
For me it's pretty much the early 90s Daewoo-built 13" with remote and osd the case was brittle and awful and the screwholes stripped their holes after the first back removal. Chassis was a pos single-pcb with the typical undersized flyback and no-name cap's and diodes. I came across 2 or 3 in total and couldnt manage to get any working except 1 which had a weak crt (couldnt get proper greyscale) saw one trashed a few months back and wouldnt even slow down the car to check it out...
Older sets? well all tube sets had problems in the longrun as opposed to a properly executed SS design IMO on the basis of additional ambient heating inside the sets which tended to eat up lytics and resistors more so i cant really decide. |
#40
Going on personal experience as a consumer (because I'm new to TV repair) the worst sets I remember were a 1987 (maybe '88) RCA ColorTrak 25" remote tabletop Mother bought to replace the CTC-40. It had little chrome tabs for the controls integrated in a feature line that you pushed down, and a flip-down door below for the color/contrast/etc. Besides the short life of the set, at night when a semi would pass it would often turn itself on at full volume - usually around three o'clock in the morning - blasting whatever was on the trucker's CB.
Also the 89/90 Zenith 19" (Sentry II I believe) which had a push on/push off mechanical power switch. Thankfully the button was plastic - Mom went to turn it on one day and there was a loud pop and sparks/smoke shooting out the switch. It was about 4 years old. |
#41
I fixed my wife's CTC-120 19" Color Trak about a year ago, and she had been dealing with touchy volume buttons since he ex-husband had it in high school in '83. It would either be too soft or too loud, and would sometimes give sudden bursts of blaring loud volume for a split second. She had no idea that there was even a problem... Thought it was made that way since it had been doing that for 25 years! Probably that's why it's the one thing her ex-husband let her have. Charles
#42
There are a couple other GE's that I just thought of that weren't that great. One was a huge projection set from the '70's, the YP chassis, IIRC. It was basically a small screen color TV that was situated so that it's image was projected on a large screen. This thing was huge and very heavy.
Then, there was another big screen that had 3 tubes, probably their first three tube model. The CRT's had large necks and I think the chassis was an ED or EP. |
#43
Isn't that the one that one of our members tried the hot-air method of cataract/safety glass removal on, and the CRT blew up in his face?
#44
I bought a Starlite (made by Randix?) 13" color TV in 1995. It was the first $100-or-less color TV I ever saw. I still have it, and it works like new still. I did have to go through three of them to get a good one at the time, though.
#45
For the worst color TVs, I would include all sets that lack DC restoration/black-level retention. That includes the Starlite I mentioned above...
