Old 09-23-2009, 06:16 AM
Hmmmpf...I thought we settled the cap issue once 'n' for all around 1965 when they (ostensibly) quit using those dreadful wax 'n' paper blivvets...Why izzit that if there's a GOOD way to do something, & a cheap 'n' nasty way, do mfgers invariably choose the predictable one ? Can't entirely be an issue of cost, what with what you hafta shell out for one of these thaings...
Old 09-23-2009, 08:29 AM
Interesting article on Wiki about Capacitors.
Seems Industrial Espionage was behind a lot of these Cap failures.
I don't know how much of this is verified fact but I've seen my share of bad Motherboard capacitors:
http://en.wikipedia.org/wiki/Capacitor_plague
Old 09-24-2009, 11:51 PM
leadlike's Avatar
leadlike leadlike is offline
If it isn't poorly mixed electrolyte, it has to be the construction of new caps:
I just fixed an lcd monitor that had a bad backlight. All I had to do was drop in four new caps. The originals looked okay, but I could pull them right off the board with my fingers. The leads stayed behind on the board, but that made it easier for me to desolder each one. I've been finding these EZ-pull caps more and more on new stuff. I can't imagine that they work so great in keeping moisture out (or keeping electrolyte in).
Old 10-19-2009, 11:40 AM
similost's Avatar
similost similost is offline
Rockin and Rollin....
Turns out this problem was because of a loose connector evidently. I ended up re-seating all the connectors and cables in the unit, and the problem went away. Been working fine now ever since the day I posted this.
Big ass speakers with too much power, and nowhere to go fast...
Altec A7-500; Peavey SUB118-HC
Modded Quicksilver 8417 Mono Amps; Tapco J1400
Behringer MX2004X; Tapco T-231; Peavey VSX; Pioneer SR-303
Technics SL-1200MKII; Pioneer RT-701; Yamaha CDX-1030; KLH Model 18
