'52 Magnavox Rescue
Well, I took this set in to save it from the dump. It needs a heck of a lot of help and I haven't decided what I'm going to do with it yet. It's a Magnavox "The American" - model no. MV 76H-1; the TV is a CT-302 chassis. The CRT is busted, it has some GE tubes dated to late 1960 and has had a few caps replaced way back when with light green Dubeliers. Interestingly, inside the cabinet I found pieces of some sort of pay receipt from the Army dated 1944.
I posted some pictures on my Flickr page: http://www.flickr.com/photos/17391692@N08/ Any on the set or suggestions are appreciated.
Hopefully that set does not use the 21EP4. If it does, you might have difficulty finding a replacement, and there's no substitute number to use.
I found a Maggie like that (but without the radio) about five years ago. It had the 21EP4 with a brightener already on it. The owner allowed me to put my tester on it, and turned out it was quite dead. Decided not to bring it home... although I probably should have being the cabinet was in nice condition.
Charlie Trahan He who dies with the most toys still dies. Last edited by Charlie; 08-03-2009 at 03:20 AM. |
Good save. Luckily, with the correct combination of chemical enhancements, you can imagine that you see a raster and you won't need to replace the crt.
![]() Seriously, happy hunting and I hope you find the tube. Nice looking set. |
I am pretty sure it's a 20-inch tube, but the label on the CRT is long gone, so which one is uncertain. Just going by old advertisements, it doesn't seem like they advertised a 21-inch set until 1953, so maybe I'll luck out. The TV chassis was covered in Sams 161, so I'll try to hunt for a copy of that in the future.
The underside of the chassis is pretty clean, miles better looking than the topside. |
You are probably right. My Halolight is a 53 model with that tube. Luckily, mine had already been replaced and is still good. The Maggie I looked at had the same exact knob layout as yours, but was likely a year later.
Charlie Trahan He who dies with the most toys still dies. |
Judging by the shape of the mask, it's a 21" tube. The 20" tubes were very, very rectangular, with nearly flat straight borders. Is it metal? I think the 21MP4 was available as early as '51.
Charles
Collecting & restoring TVs in Los Angeles since age 10 |
Isn't that the special "cats eye" CRT? Or is that the "cyclops" model that watches YOU?
![]() SR |
It is not a metal tube, and not very heavy either. I probably won't know for sure what it is until I find that Photofact.
I have the photofact, 161-4. Got a spare, if you want it drop me a line. Looks like lots of versions covered in this one, using one of the following crt's:
17BP4 17BP4A 16TP4 19AP4 20CP4 The one pictured in the Sams is ch.CT303 which uses the 17". Hope this helps.
Bryan |
