Old 07-10-2009, 01:23 PM
zenith2134's Avatar
+1. I wanna see!
Old 07-10-2009, 08:06 PM
MRX37 MRX37 is offline
Originally Posted by radiotvnut View Post
Oh come on, just pull the back and let us see the insides. Then, we can tell you real quick what generation you have.
Not tonight, but tomorrow I'm gonna open it up to clean it out. then I'll snap some pics for you guys.
Old 07-10-2009, 08:38 PM
Yay
Old 07-11-2009, 10:02 AM
Okay, here's a shot of its insides:
My god what a birds nest of wires!! if I ever have to tear into this thing to fix something... oh lord...
Anyway, I'm going to give it a good cleaning inside. Perhaps you guys can now see what chassis I have, and maybe list any issues I might run into with it.
Old 07-11-2009, 11:01 AM
That's the 2nd generation chassis that uses the 9-160 power supply/horizontal sweep/HV module. These modules are commonly found with loose connections and those edge connectors often give trouble. If you ever have to pull it apart, it would be wise to resolder everything on the 9-160. Also, clean all the edge connectors. Another common problem with these sets is the flyback blowing up. When they burn up, it sounds like the 4th of July. If I were you and planned on keeping the set, I'd try and secure at least a good 9-160 and a 9-155 video output module as spares. These boards are getting harder to find. Zenith didn't really intend for these sets to be repaired to the component level. They wanted the technician to swap the whole module. I used to do that when I first started repairing TV's; but, I started repairing as many as I could to the component level when 9-160's started costing more than what the TV was worth.
Old 07-11-2009, 11:48 AM
Um,, one of those stickers says 9-149 I don't know what it is as I had to button the TV back up, but yeah.
A more extended viewing session shows some color bleeding at anything above moderate color levels.
I think based on the slow warm up time and the color bleeding, this tube is getting tired, so I may keep it or I might not.
Old 07-11-2009, 12:22 PM
Those Zenith in-line "tri focus" tubes did not last as long as the old delta gun tubes. They're not nearly as bad as a '90's Zenith tube; but, they certainly don't last like the older tubes. The last several 25" system 3's that I've found had a weak CRT.
Old 07-11-2009, 01:18 PM
Mmm this CRT is still nice and bright. Convergence and focus around the corners is a bit off, but it's in far better shape then the 1997 Zenith it replaced. I guess for now its staying.
Though... I now work fopr a company that sells LCD TV's, and I'm starting to warm up to them...
Old 07-11-2009, 08:25 PM
NO!!!! Don't go over to the "other side"!!
Old 07-12-2009, 08:04 AM
Well, they do have their plusses, I'm not gonna lie.
Convergence is not an issue for one. Black levels are surprisingly good as is the contrast ratio. Colors look as good as a modern CRT, make of that what you will. They also have an abundence of A/V inputs/outputs.
Also, they're easy to fix when you have parts. Replacing an LCD screen is easier and less dangerous then replacing a CRT. No high voltages to shock you, and no heavy tube that can implode...
Oh they do still have their drawbacks though. I wouldn't trust the caps in their power supplies for starters. Standard definition video rendering isn't as good as a CRT's. It looks okay, but a CRT can do better. They aren't as dangerous as a CRT, but they're more fragile.
So yeah I'm starting to warm up to them, but I'm not abandoning CRT's, because they can still do something these LCD TV's can't. See, I look for capabilities in something electronic and while these LCD TV's can do a lot, enough to where I actually have an interest in one, there are things they still can't and probably will never do as well as a CRT can.
Old 07-12-2009, 11:41 AM
Keefla Keefla is offline
i have to agree with MRX37 on the lcd front. while i dont own one my father does, the one he has is over 3 years old now (yeah i know its sad to say 3 years is a long time) .... immediatly out of the box it looked like crap but after he and I spent a few minutes messing with the picture setup it really does look quite decent. as usual they have the color and contrast jacked to the moon, but once they were at reasonable levels...and with HD going to it the picture is surprising. That being said im keeping my '78 sylvania till it grows legs and brings itself to the dump.
Old 07-12-2009, 01:03 PM
Yeah, this one that I'm playing with, I had to actually adjust it up because it was a bit dim, but after a few slight changes to the brightness settings, it's pretty good.
