Old 04-20-2009, 08:04 PM
I fixed it. I forgot that the menu button had to be pressed and held until the menu disappeared before entering 9-8-7-6-enter. Once I got into the service menu, I turned off the front keypad lock and the channel lock. It now works like any other TV. I did check the CRT just for fun. The red reads in the low end of the "good" range and the blue and green read "on the fence" between good and bad. I decided not to rejuvenate the tube since it made a watchable picture since rejuvenation often makes these tubes worse.
