Old 01-29-2009, 08:42 AM
tentoze's Avatar
tentoze tentoze is offline
Twangophile
Picture anomaly question for the TV Experts
Within the last week or so, my trusty old JVC 32" CRT tv has developed a problem. The top 2" or so of the image are garbled, and actually invert the image on screen. I've tried to capture the phenomenon in the attached crummy pic, where the letters on the right are upside down and backward. Does anyone know if this is something that can be fixed by a service guy, or is it a symptom of the thing being on its last legs? Any advice is appreciated.
"If evil exists, it's a pair of train tracks,
And the Devil is a railroad car."
-Josh Ritter-
Old 01-29-2009, 10:30 AM
kx250rider's Avatar
REAL TVs have TUBES!
That's a classic vertical problem ("Foldover"). It's caused 99% of the time by a dried out electrolytic cap. Does it get better/worse as the set warms up? If so, the offending cap is usually easy to spot with a can of freeze spray. Otherwise, another method is to measure all the electrolytics in the vertical circuit with an ESR meter, or the old-fashioned way; scope it.
I don't ever speak for other techs' fees, but this job should be in the lowest category...
Charles
Old 01-29-2009, 11:20 AM
Yep, likely bad caps in the vertical circuit. If you don't have the equipment to check them; just replace them all (probably not over a half dozen). The caps will be located close to the vertical output IC. The IC is a stand up device mounted on a heatsink. In some cases, bad caps can take out the vertical IC; so, I'd go ahead and start replacing caps before they take out the IC. If the IC goes, you'll just see a straight line across the center of the screen.
Old 01-29-2009, 11:23 AM
tentoze's Avatar
Twangophile
Thanks for the input, guys. I'm no tech, and no way I'd go inside this thing myself- but at least I think I know now that it should be repairable for a reasonable cost.
-Josh Ritter-
Old 01-29-2009, 02:39 PM
zenith2134's Avatar
Had a JVC AV-2672S from 1992 with the foldover problem. I didn't know how to diagnose and fix sets yet so it went to the shop. 75 bucks for a replacement of the IC, associated electrolytics, and labor. Worked like a champ for years til I gave it away. Good luck.
Old 01-29-2009, 04:53 PM
centralflori's Avatar
centralflori centralflori is offline
AK Member
I think we may have that same tv. What is that model number?
McIntosh MC206,MX130,MVP861,RGPC1200,Magnepan Tympanis (1pr.),KEF 104/2's (1pr.),ESS PS8H's (1pr.),McIntosh XR240's(1pr.),Klipsch KLH-10(1 pr.),SilverBullet 4.0(1pr.),White Zombie 1M Silver IC(2pr.),.5 meter Silver IC(1pr),30' Silver Cables w/large spades (3pr.)
Old 01-29-2009, 05:03 PM
tentoze's Avatar
Twangophile
Av-32920.
-Josh Ritter-
Old 01-29-2009, 05:12 PM
AK Member
Same model! Do you have a digital converter box hooked up?
Old 01-29-2009, 05:13 PM
tentoze's Avatar
Twangophile
No, I'm a Luddite.
-Josh Ritter-
Old 01-29-2009, 05:20 PM
AK Member
Don't know if it has anything to do with having the digital box hooked up, but I can set mine on wide screen and not see that top couple of inches. Reason I got the converters is where I am at I would see nothing but snow without them. With them it's like having satelite without all those pesky channel choices to make. You know like ESPN or HBO or music channels. Using the converter boxes all the regular local channels have multiple channels that I did not know existed even with satelite. Of course if you have satelite or cable the point is moot.
Old 01-29-2009, 06:54 PM
MRX37 MRX37 is offline
Yeah I'm going to also say a bad cap or two. Easy fix really. Here's some signs that will let you know when that TV is on its last legs:
The picture becomes dim and tinted, even with the brightness and contrast at max.
The picture is still tinted even with the color turned all the way down.
You see smearing (color bleeding) to the right of bright colored objects, especally bright yellow, red, and orange objects.
Any or all of those signs usually mean that the CRT is dying, and when that goes, nowadays it makes the TV worthless. From your pic though, the picture looks bright, seems to have good focus, and I don't see color bleeding. Get those caps changed and it'll probably give you another good 5-10 years, maybe longer.
Old 01-30-2009, 12:42 PM
tentoze's Avatar
Twangophile
Just went by a repair shop local to me (very local, actually, only about 1.5 miles away, been in business since 1946), described the problem and the estimate to fix is $150-175. Sounds a heck of a lot better to me right now than $1500 or more for a new whizbang flat-screen. Now to coerce my son to come over to help me load this beast in the truck...
-Josh Ritter-
Old 01-30-2009, 03:59 PM
AK Member
If you like the crt better thats great, but if you shop around you can get one of those flat panels for a whole lot less than $1500.
http://www.costco.com/Common/Categor...=en-US&topnav=
BTW there are many fine merchants on the web as well as brick and mortar, and I don't have any affiliation with this one, other than I buy crap there.
PS. Hope I didn't screwup your thread and make it a question of value.
Old 01-30-2009, 04:49 PM
freakaftr8's Avatar
Convergence freak!
Yeah, look around, less than 150 will get you a nice working set! CRT sets seem to be falling out of trees here lately.. I just got an old 1988 Sony 27" with remote and matching stand for 20 bucks yesterday and it just needed a bias dreive and focus adjustment. Looks excellent for a 21 year old set! I have seen HD Plasma sets around here for 500. Although I wouldn't own one as plasma seems to be becoming archaic technology after the introduction to OLED technology..
