Old 11-29-2008, 07:28 PM
mbates14 mbates14 is offline
Originally Posted by MRX37 View Post
Well, I replaced every cap around the vertical IC, and the problem is fixed. Ran the Tv for awhile and it's not doing anything funny, so I think I'm finally done with it!
hehe. knew it.
Old 11-29-2008, 08:59 PM
MRX37 MRX37 is offline
It's just weird because failing caps usually cause the vertical to shrink. Eh, I didn't build the damn thing.
Old 11-29-2008, 09:37 PM
yes, and no. depends on WHICH cap fails.
you have bypass caps, shaping caps, filter caps, coupling caps. and on and on the list goes.
Old 11-29-2008, 11:31 PM
Bad caps can cause just about any problem that you can dream up in a piece of electronics. Never underestimate what a bad cap can do!
Old 11-30-2008, 12:01 AM
Could it, oh say, compensate for another failed component in some way?
Like if cap A fails which drops the voltage, but regulator B also fails causing the voltage delivered to the cap to spike, compensating for the drop...
