Old 11-10-2008, 05:12 PM
sealforvr sealforvr is offline
AK Member
Early 80's Curtis Mathis
Anyone know anything about this model?
http://phoenix.craigslist.org/evl/clt/898291931.html
Looks top of the line or close to and was built before George Curtis Mathes jr died.
TIA
Brock
Old 11-10-2008, 05:27 PM
freakaftr8's Avatar
Convergence freak!
There's one for sale here in California San Fransisco Craigslist that pops up from time to time as well. Friggin tank man! The one out here is stated that the TV doesn't work. All 100% solid state. Nice set if you have the room.
Old 11-10-2008, 05:36 PM
Probably made by NEC. That's who made the chassis for most CM sets during the solid state era. I wonder if that cabinet is real wood or particleboard. IMHO, the CM sets from the late '70's and early '80's were not the best quality, given what they cost. This TV may be an exception.
Old 11-10-2008, 06:57 PM
zenith2134's Avatar
My vote goes to Particleboard. Think about the amount of raw materials that wood be needed for that size cabinet! But, it could be solid wood I suppose.
In any event, the SS Curtis Mathes aren't too special.....and it wasn't long before they sold out to some other manufacturer at this point.
Old 11-10-2008, 07:39 PM
Chad Hauris's Avatar
I think it would have an NEC chassis. We had one almost exactly like this at our shop but the CRT neck accidentally got broken so we salvaged the parts and discarded the cabinet. It is incredibly heavy dense particleboard and plastic moldings, not real wood.
Chad Hauris
Old 11-10-2008, 09:09 PM
peverett peverett is offline
I used to have a late 1950s version of this Curtis Mathis with B&W TV. It was real wood and weighed so much that it took 4 people to move it.
Old 11-11-2008, 01:04 AM
freakaftr8's Avatar
Convergence freak!
This is much like everything else in the world, at one time it was about the pride in a product. Now it's about the mass production and cutting costs..
Sad... Truely sad....
Old 11-11-2008, 01:57 AM
My 1960-ish CM B&W combo is made of heavy particle board with real wood veneer over it, I'd still say it was a good quality cabinet compared to modern P-Board furniture.
Old 11-11-2008, 11:04 AM
kx250rider's Avatar
REAL TVs have TUBES!
The Curtis Mathes cabinets went to pot in the 70s, sadly. All the sets after that, even the big combos, had particle board frames with veneered paneling, and lots of fake carving (moulded plastic). The high-end ones from the late 50s (or whenever they got going), up to the late 60s, were very elegant, real wood cabinets. I had to cut one apart to fit it in the trash, and the top panel was a real solid wood plank; not even plywood! (That was in the early 80s, and the set was junk due to abuse by previous owner).
Charles
Old 11-11-2008, 12:26 PM
"The most expensive TV in America-And darn well worth it !!" Ho-Kay.....
Old 11-11-2008, 12:56 PM
Charles
I junked a '74 CM solid state combo that was in one of those cheap particleboard and plastic cabinets. Weighed a ton! The chassis was modular and was built by NEC. The CRT was a 23" delta gun Westinghouse tube (which was toast). The record changer was some cheap plastic BSR. Nothing on this unit worked. I saved the el cheapo speakers for use in old radios and I saved the TV chassis just in case a part was needed off of it.
BTW, does anyone know when CM discontinued tube-chassis TV's? Years ago, I had a CM tube type color console in a real wood cabinet. The chassis was an RCA clone.
Old 11-11-2008, 01:11 PM
AK Member
OK, sounds like a good one to pass on then, Thanks everyone!
Brock
Old 11-11-2008, 09:28 PM
I just got a 1971 CM tube type color set, so they were making them at least through then. It is an RCA CTC-25 type chassis with some upgrades...it has cooling fins on the power transformer, a 6BQ5 audio output tube, and an IC audio demodulator. It has a 25V rectangular type picture tube but the cabinet is made of particle board, masonite and plastic.
Here is a video
http://www.youtube.com/watch?v=fqsW7MwFcqI
Chad Hauris
Old 11-12-2008, 09:53 AM
kx250rider's Avatar
I think Chad's is probably the newest tube set I've seen from CM... I had one of those a long time ago. Definitely an RCA clone.
Charles
Old 11-12-2008, 10:20 AM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
I thought it was "jr" who didn't really care about the product and let the company go to hell? But I knew a lot of people who fell for that idea of CM "superiority". Zenith should have just shown a picture of a circuit board burned to a crisp by tube heat, and called it a day!
From Captain Video, 1/4/2007
