Old 09-16-2008, 06:46 PM
electroking's Avatar
a- v- karma member
Originally Posted by nasadowsk View Post
Canadian set - the schematic references 25hz AC power operation!
You're right, and this brings a question. A transformer type set designed
for 25-Hz will work fine on 60-Hz, with only improved filtering. What about
a voltage-doubler set like this one?
By the way, the actual set discussed in this thread is the 60-Hz model,
as evidenced by the fact that it has a single filter choke.
Old 09-16-2008, 11:12 PM
JesusJones JesusJones is offline
AK Member
Damn wish I had looked here an hour ago hahaha.
I just ordered all the caps by tediously looking inside and turning them and what not. But it's all good. And thanks for the schematic. Hopefully most of the voltages are near spec. I can't wait for those caps to get here. I'll tell you guys what happens as soon as I do.
And I"m pretty sure this set has two Chokes. And it also says on the back it's meant for 60hz.
I can't wait
Rudy
Old 09-17-2008, 08:21 AM
a- v- karma member
Filter Choke
I can't wait
Rudy
Hello again,
Hope the schematic is readable. I can read the posted images on my screen,
but printing yields marginal text for me. Il you look at the chassis layout
(second image in post 57 above), you will see the chokes on the left
side, L-500 and L-501, the latter for 25-Hz only. On the picture you posted
earlier, I can only see L-500. By the way, you could trace the wiring to
this choke and check with your ohmmeter to make sure it is not open.
The nominal resistance (36 ohms) is given on the schematic.
T-301 near the top looks similar, but is the audio output transformer.
Good luck.
Old 09-16-2008, 11:14 PM
It would also have improved filtering, as the filter caps are approx twice the size needed.
