I also try to stay away from NTE/ECG transistors, especially in power supply and deflection circuits. Sometimes they work and sometimes they will blow up in your face. Many times, it's actually cheaper to go with the original part than an NTE sub. Like rcaman said, put an original back in there. Another word of caution: Many parts houses sell inferior transistors at a cheap price. Many of these will short instantly. I think places like Tritronics, Mouser, and B&D sell decent parts. I remember finding some STR53041 Zenith voltage regulators at a "good" price. It turned out that every one of them were bad!
You might want to order 2 or 3 HOT's. That will give you some "play room" in case you blow one while troubleshooting.
I'm sure whatever is bad in the pincushion circuit is causing the HOT to blow. If I had a schematic, I could probably tell you some things to check.
