Old 03-13-2008, 10:12 PM
Whirled One's Avatar
Whirled One Whirled One is offline
Originally Posted by Old1625 View Post
Those were remarkable little sets for the time. But remember....
1) The dot pattern on the screen is of exactly the same density as for larger CRTs of the time. This means iffy resolution at best.
I forget the CRT numbers, but the original CRT type that GE used for the first model-year Portacolors was indeed like that, but the later one used after the first model year was much better (if you put one of each side-by-side, the difference in dot pitch is really easy to see!). However, when GE switched the PortaColor from a dot-phosphor CRT to a stripe-phosphor CRT in the early 1970's, the resolution went right back down again.
