Screen savers are only still around because some people like to look at them. As an early TV set enthusiast, displaying fish is something I am not really keen on doing. ![]() John |
tvontheporch.com |
Sony Trinitron Fan |
I will categorically say, "technology has rendered a screen saver nothing more than just purty pictures and waste of processing power". At least as applied to LCD monitors. I do recommend that you just let the monitor go to standby (the green or blue power LED will change to yellow/amber) when you are not using the monitor. If you plan to leave the computer running 24 hours per day, set the monitor power-down to maybe 30 minutes in the Windows settings.
Gotta love it. Two pages of replies and jokes and STILL not a technical answer regarding whether a modern LCD "needs" a screen saver or not. I don't care about Windows power-saver features. I don't care about what people do based on which way the wind blows their grass. I don't care about if a pigeon alights on the car but only on the second Monday while Aunt Helon's lumbago is flaring up.
Does, based on the design of the interleave, the refresh rates, the graphics mode and so forth, does a modern LCD need a screen saver, or is it immune tioburn in due to any of those technical issues?
Retired USN. "Good ........ bad ........ I'm the guy with the gun." Ash, Army of Darkness |
![]() In other words, a screensaver is not necessary for an LCD of modern design.
That's headed in the right direction. Why? What makes them different?
Here: http://en.wikipedia.org/wiki/LCD Probably everything you wanted to know about how an LCD works. If this doesn't answer your question, I don't know what will. |
There ya go. THANK YOU.
The inside of the front of a CRT is coated with a phosphor which reacts to light. The gun at the back of the tube projects a picture onto the phosphor and the image is displayed. If this image is left on for an extended period, the areas where the phosphor is lit by the beam will become burned by the beam.
LCD's use a liquid sandwiched between two layers of glass. When electricity is applied to part of the liquid, it changes to a darker color. This is physically different from a CRT, so no burn can occur.
