Old 11-04-2007, 08:58 PM
Cheap HD
Found a Samsung HD tuner at the GW for $25 today, didn't pick it up at first but went back after I saw what they were going for on eBay.
Hooked it up to a 21" CRT monitor I got for free, added a pair of 60 year old Rabbit ears and a pair of PC speakers and viola, HDTV!
I'm 70 miles from Los Angeles and with just the rabbit ears I'm able to pull in a few stations, most of them pixilate somewhat but CBS has been coming in strong for an hour, I imagine with a good bow-tie antenna on the roof I could pull in all the LA stations fine.
Old 11-04-2007, 09:15 PM
avguytx's Avatar
avguytx avguytx is offline
AK Member
Well, actually, you're watching HD downconverted to SD since it's on an SD monitor. (but I'm sure you already knew that!) But it's a darn good looking picture on local channels isn't it?
I wish I could come across one of those for my mom back in Arkansas who is freaking out since I put satellite in at her house and the local channels are based out of DFW. She's not thrilled with the rabbit ears pulling in analog signals and her "soap opera" and local news looking fuzzy. It would be cheaper than buying her a new HD or SD TV with the off air tuner built in (although that would be easier for her to run).
Nice find!
"....we can clone sheep, but we apparently can't make a short paper tube without a raised seam." A quote from Art Dudley, Stereophile, Oct 2008, in regards to Lowther coil/coil formers.
Old 11-04-2007, 09:47 PM
peverett peverett is offline
Conveters are also available at Newegg.com. However, they are $80, not $25. The ones on Newegg output a composite video signal. With an RF converter(available at Wal Mart in my area), you can use this on pretty much any TV. I receive the channel I watch the most with no problems using rabbit ears. However, I am only 30 miles from the transmitter.
The funny thing is that I cannot receive the HDTV signal for the channel with the strongest analog signal. They must be using all of their power to transmit the analog.
Old 11-04-2007, 10:17 PM
No i didn't? but I admit I don't know all the fine points about HD.
When the monitor is hooked to a PC it's capable of going as high as 2048x1536 resolution so wouldn't it be able to do 1080i?
I'm using the VGA output of the tuner and it's selectable from 480p to 1080i so I assumed the monitor would switch to accomodate it.
Here's a shot of the back of the tuner, it has an RF output so I'm assuming I should be able to use it with a vintage set as well?
I need to read the instructions I guess.
Old 11-04-2007, 10:47 PM
OvenMaster's Avatar
DTV blows
$25 at GW?! My God, I don't even see them for sale brand new here, and they're already turning up used, in Goodwill stores. in SoCal??
I live in the wrong part of the country, I swear.
Tom
Tom
Old 11-04-2007, 11:25 PM
dr.ido's Avatar
dr.ido dr.ido is offline
If the box is set to output 720p or 1080i you will be able to watch HD on a VGA monitor if the monitor will handle it. Your monitor should handle 720p, but it may not handle 1080i correctly. I've tried running the VGA output from a HD set top box into several different VGA monitors. Some handle it better than others. On some monitors I got an image that was stretch or had horizontal fold over that was too far out for the monitors adjustments to correct it.
The RF output on most of these set top boxes is just a loop through output that passes the signal from the antenna to another device. You will still need an RF modulator hanging of the composite output to use it with a vintage TV after analog transmissions go dark.
Old 11-04-2007, 11:38 PM
If the monitor is doing a good job with the interlaced output of the box, then you are indeed seeing a full-resolution 1920x1080 signal on that monitor, better quality than most CRT-based HD rear projection TVs and more detail than any 720p projectors (and far more detail than any plasma TV, except the few latest ones that can actually display 1080p).
Good find, that box. As you can see, it has connections for every type of display out there, from RF-only SDTVs like our antiques to the latest HDMI-input LCD digital flat panels (with a $10 adapter cable).
If you (or anyone else here) would like to think about collecting HD receivers, look for an RCA DTC-100. It was the first reasonably-priced HD tuner (US$650 when new). Another good early one would be the Panasonic TU-DST50 or TU-DST51.
Old 11-04-2007, 11:53 PM
Dave A's Avatar
Dave A Dave A is offline
Eric,
That looks like the SIR-T451 model. An 8VSB (off-air) only model. Good for off-air only. It will not receive in-the-clear cable QAM signals. It has been around for two years or more. As such, do not expect too much from it's internal processing on digital. Two years is a long time ago in digital growth.
Your HP monitor is showing what looks like 16x9 HD to me via the RGB connection which the manual says it will do. So far, so good. Looking at the manual for this box, it says that it will not letter-box 1080i signals on a 4x3 so you are probably looking at the 720p signal.
The manual also says it will downconvert the HD to 480p via the usual video out connector for viewing on a conventional set in conventional definition. It looks like you can set the box to letterbox or "zoom" (a 4x3 center cut of the 16x9 to fill the 4x3 screen) via the remote on the 480p.
The RF signal will only be a 480p signal for a regular set. The manual is not clear if you can letterbox or zoom on this signal. I doubt it. It is also not clear if the RF signal will pass any of the digital channels as down-converted.
You can download the manual here;
http://www.samsung.com/us/support/do...ype=UM&vType=L
I picked up a full digital LG DVD recorder box a few weeks ago for $250 or so. It has the full 8VSB and QAM tuner for use on my basic cable. Composite, component and HDMI outputs. It's tuner is better than the LG 23" HD set I am feeding with the same full tuner. I am amazed how much digital Comcast is passing on this signal. Local 4x3 analog channels, local 4x3 digital channels, local HD channels, digital 4x3 versions of some cable channels (but not HD on those) and a bunch of music channels. I live in a valley too far from the xmtrs for off-air. DVD recording is in 480p no matter what signal comes in.
Welcome to the confusing world of digital,
Dave A
Old 11-05-2007, 01:55 AM
Virtually any computer monitor should be able to handle 1080i. It only requires the same horizontal scanning frequency at 540p (almost all computer monitors can easily handle 600 lines). The catch is that you might not be able to set the size for a 16x9 image. Most LCDs can't handle an interlaced signal.
Old 11-05-2007, 02:01 PM
As Andy said, LCD displays work at specific resolutions and frequencies, so they must be labeled "HDTV ready" to work with DTV signals (other than 480p, which is the same as original VGA 640x480 60 Hz). CRT monitors like the one Eric is using work with a wide range of signal resolutions and frequencies, and they also usually have vertical-size controls (unlike LCD displays). It should be easy to set the Samsung tuner to 1080i mode and reduce the height on the HP monitor to a 16:9 shape (as you may have already done, Eric); I have done this with several CRT monitors and HDTV tuners with RGB/"VGA" outputs, with great results. The only question is how well specific monitors handle interlaced signals. I have an older Sony that does not like interlace, and a brand-X monitor (Gem) from Fry's Electronics that handles it flawlessly.
Old 11-05-2007, 02:12 PM
kx250rider's Avatar
REAL TVs have TUBES!
Is that an off-the-air digital receiver like Eric shows, or just satellite? It has a DirecTV card. I'd pick one up as a collectible if I could actually use it, but not a DSS receiver. I have a stack of those waiting 'til I need to cut a cord off them for some other purpose
Charles
Old 11-05-2007, 09:33 PM
Good information all, thanks.
dr.ido is correct about the antenna, it's just a pass through, didin't work when I hooked it to a TV, oh well, I've accumulated a few RF modulators.
Dave, thanks for the link but this came with the manual and cables!
Chris, yes, I adjusted the monitor to get the shape close to 16X9, when the box is switched to 480 the monitor switches accordingly.
Old 11-05-2007, 09:35 PM
Tom
Well Tom here in Cali it's like omigod, it's sooo last years model, like we got to get a new one fer shur...
Old 11-06-2007, 03:31 AM
dr.ido's Avatar
Here's a couple of HD boxes that were mixed in with the last big stack of DVD players I picked up.
This is an NEC NHD-2000. It's actually made by Macro Images Technology, but I can't find any information on it either under their model number or the NEC model number. It looks to be a decent box with composite, S-video, component, RGB and HDMI outputs. It has access to the menus via the front panel controls (important here where most of these arrive without their remotes). Strangely the board appears to have a PCI connector, but I don't know what it's for. Unfortunately the SMPS IC blew it's top and I can't indentify what IC it is, so I doubt I'll ever get it doing unless I find another one of the same model.
This is a DGTEC DH-2000A plus. This one is older. It was one of the first cheap HD boxes around here (at AU$599). It has composite, S-video, component and RGB outputs, but no DVI or HDMI. It looks like there is a similar model that has a built in DVD player, but I haven't seen one. It was probably dumped because someone set it to output something their TV couldn't display and couldn't work out how to change it back (this happens a LOT around here for some reason). There is no access to the menus without the remote, but you can change the video mode by holding down the channel buttons on power up. Of the 3 available video modes that it will output via the RGB connector 2 work on the AOC 17" VGA monitor (576p, 1080i?) on the test bench. The other (720p?) it won't sync to and displays an error that it can't sync to 28.1kHz (which doesn't make sense for 720p. I haven't tried it on any other monitors yet.
The picture from channel 9 HD in 1080i (I think). The monitors adjustments are at 100% H-size, but the image still isn't quite full width.
Old 11-06-2007, 11:15 AM
kx250rider's Avatar
Oh Brother! I haven't heard that talk since I was at the Sherman Oaks Galleria in '82! I saw the movie Valley Girl, so my friend and I decided to get on the bus over the hill and see if it Valley Girls were really like that... Some were, and later I was with one for 9 years... Now I have a Texas cowgirl and realize that a Valley girl was never for me
Gag me with a spoon..... Totally!
Charles
