Old 06-05-2007, 07:23 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
shielding played an important part
In many of the early color sets (as well as b & w) for that matter, it was imperative to replace any shielding removed for any service operation.
Failure to replace shielding after service could cause a miriad of problems.
Even something as simple as a broken ground connection of the rf cable between the rf output and the if section could cause very weird problems if one wasn't aware of the result of such failures.
Make sure when you are restoring your oldies that care is taken to replace tube shields as well as shields around sensitive areas.
My number one rule of serving was, if the engineers put it there, it must be there for a reason!
Happy restorations.
[IMG]
Old 06-05-2007, 09:33 PM
peverett peverett is offline
It seems that many TV servicemen did not follow this rule. I have seen many a set with the the shield on the tuner missing!!!. I am sure a lot of their customers had sets that did not perform as well as they could have because of this.
(other items that are often missing are the screws to hold the back on).
Old 06-06-2007, 04:49 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
I've often spoiled the lovely brown patina of a tuner shield when someone else's chassis was on the bench. Ever wonder how the 10-20 years of accumulation got there? Two smokers dust, dog dander, and lest we forget pan-fried meat most mornings and evenings!
What was most annoying was the little grease-impregnated sponge inside Magnavox shields. The sponge would disintegrate over time, and the tuner would need a massive hosedown with Blue Shower to get the stuff out!
Old 06-06-2007, 05:18 PM
Old 06-06-2007, 05:45 PM
rcaman's Avatar
rcaman rcaman is offline
dishwasher is a good idea. i take a lot of projection chassis to the car wash that has been infested with rodents or bugs. water will not hurt anything as long as it had dried out before power is applied. steve
Old 06-07-2007, 04:48 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
Workinh in HVAC is to my advantage, as I have sheet metal readily available. I can make new shields as needed.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 06-15-2007, 10:11 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
what is that little sponge for?
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
Old 06-15-2007, 10:36 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
I've always heard about servicemen washing a really smoky chassis in soap and hot water, but have never really wanted to try it, for fear of destroying pure unobtanium. Does it really work?
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
Old 06-15-2007, 10:48 PM
Old 06-15-2007, 11:17 PM
Chad Hauris's Avatar
I have not personally encountered the Magnavox tuner sponge but this sounds like a tuner cleaning gimmick that was meant to be installed inside the tuner shield and impregnated with tuner cleaner so it could "automatically" clean the contacts....seems like it was a Chemtronics product.
Chad Hauris
