Old 12-13-2006, 08:44 AM
shrinkboy's Avatar
shrinkboy shrinkboy is offline
AK Member
Location: Oak Cliff, Texas, just across the Trinity River from Big D
question about RCA XL-100
guys-- i just picked up a 1994 model as mentioned, 27" screen, for a guest room. no remote, no manual. i cannot figger out how to get it to show signal from DVD player. has cable coax input and yellow video input. i have sat coax going into coax input, DVD going into yellow video.
there is no control for going back and forth between the two sources. there is no S-video either. what am i missing?
thanx
Technics SL1700/SL1400
Marantz CDR700/Entech205.3
Onkyo TA-RW 311
TEAC x2000r/Realistic TR3000
DBX CX-2/Phase Linear 400 Mk.II
Acoustic Research AR3a
Old 12-13-2006, 08:48 AM
colortrakker colortrakker is offline
Thinking in color...
if it's anything like other Thomson sets of that vintage, tuning the TV to channel 91 should do it.That's where the video input is on a lot of those sets, including my '95 ProScan (CTC-169 chassis).
Good headphones make good neighbors.
Old 12-13-2006, 11:13 AM
shrinkboy's Avatar
AK Member
thank you colortrakker. will give that a shot....much appreciated
Onkyo TA-RW 311
Old 12-13-2006, 01:49 PM
If that doesn't work, then there would have been a TV/video button on the remote. Most universals should be able to do that for you. If it's a hotel model, then that feature might be disabled. Can you access all the menus?
Old 12-13-2006, 03:20 PM
shrinkboy's Avatar
AK Member
don't think it was a hotel model. all menus can be reached with the menu button on the control panel. i've even got a couple old rca remotes around, but neither works, even with fresh batteries...
Onkyo TA-RW 311
Old 12-13-2006, 07:03 PM
shrinkboy's Avatar
AK Member
can't get it to go to channel 91, or 92, or a lot of channels btw 68 and 99. ideas?
Onkyo TA-RW 311
Old 12-14-2006, 12:49 AM
rcaman's Avatar
rcaman rcaman is offline
hey i bet you if you push 00 it will go straight to video input. try it. steve
seriously these sets use 00 for video input.
Old 12-14-2006, 01:16 AM
If it wont go over channel 69 its not in cable mode; it thinks it's hooked up to an antenna.
Old 12-14-2006, 09:42 AM
shrinkboy's Avatar
AK Member
good ideas, will keep pluggin' guys, thanx
Onkyo TA-RW 311
