Old 01-13-2025, 09:13 AM
The switch can be deleted for now. Then turn the color all the
way DOWN. Fix the set so its as good a B&W set as you can.Then turn it up & deal with any actual color poroblems
Zeno
Old 01-13-2025, 11:21 AM
Zeno
OK, will do.
Old 01-14-2025, 03:01 AM
OK, So I have a Question concerning picture tube checkers, I have a B & K Model 465 CRT Tester that was given to me for free more or less by someone locally that I bought a couple of old radios from on Facebook Marketplace, and when I tested the Picture tube on this TV on this CRT Tester the Green and Blue guns tested like brand new yet (the meter was pegged out at the top in the emissions test) but then the red gun didn't budge the needle at all (it was showing no cutoff and the red gun was registering all the way at the bottom of the meter) This CRT Tester I have uses a switch with 3 positions: Position one (If I'm understanding this correctly) is the B/W test setting and also the Red Gun test setting for when you're testing color picture tubes, then the second setting is Green, and the third Setting is Blue.
Now this is where I'm kind of confused in how this CRT Tester works and if maybe I'm doing something wrong and maybe why I came up with a "dead" red gun result in my test, the instructions for this tube tester makes it sound like there is actually supposed to be a 4th setting for the CRT emissions/Cutoff test but when I actually go to flip through the settings there's only 3 clearly discernable settings on the switch. The Instructions for the Cutoff/Emissions Test reads as saying that if you're testing a B/W Tube you leave the tester's test mode switch in the B/W setting but if you're testing a color tube you need to switch it to the Red setting and follow the directions for the test and repeat the directions for the Green and the Blue settings.
But there's clearly no separate settings for B/W and Red it acts like (and its marked as such too) that the B/W and Red test settings are one in the same setting on the CRT Tester.
Does anyone here have any experience with this particular CRT Tester or ones similar to this and if so how is it supposed to work, because the Instruction manual is leaving me with more questions than answers, and also how common is it for one single color gun to just randomly die on a TV when the rest of the color guns test super strong yet, and also is it possible that the picture tube is actually good yet on all three guns and I just wasn't testing the Red Gun Correctly?
Any help with this issue would be appreciated.
Old 01-16-2025, 11:23 PM
You are correct. The 3 position switch simply selects which color gun you're testing. So you need to re-set the cutoff control for each gun when you move between the 3, because there's no memory of the 3 cutoff settings. Some fancier testers have 3 separate cutoff controls and 3 meters so you can compare all 3 color guns simultaneously.
Old 01-17-2025, 12:44 PM
That's what I thought but when I would go to adjust the red color gun settings and do an emissions test on the red color gun in my picture tube I get no needle deflection/movement from the meter but when I would test the green and blue color guns in my picture tube I get deflection/movement meter that shows that the picture tube is still good yet, but how is it possible for a picture tube to have really good testing green and blue color guns but a dead testing red gun?
Old 01-17-2025, 12:56 PM
Because they are 3 independent guns so there could be a mechanical failure of one component, and they can even wear out differently depending on how the drive controls were set.
Old 01-17-2025, 01:05 PM
But if you know all the guns work in the set, I suppose there could be something wrong with the red circuitry in the tester, right? Did you get a decent black and white picture like Zeno suggested? You could test a known good black and white crt to verify if the b/w, red switch position is goofy.
Old 01-17-2025, 03:33 PM
It seems kind of weird though that only one of the color guns would of failed catasctrophically but not the other ones, especially if it was a mechanical failure.
I was attempting to do a black and white setup on the tv and all I would get was a bluish green tinted picture with a slight bit of red in it, I couldn't really get the color to really go completely away.
Another weird thing is that the Color and Tint controls and the brightness and contrast controls don't seem to do anything with the TV and also the color adjustment and AGC Height and Vertical Linearity pots are acting like they might have tin whiskers because they do some weird things to the screen when I adjust them.
I have another Sylvania Color TV that is from 1974 that the tuner has failed on it, but it uses the same size of tube, and the picture tube was basically brand new on it because it was never used by the previous owner of it, I wonder if I could try to do a picture tube swap and see if it makes a difference with the TV?
