  #31
Old 05-31-2024, 11:20 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Originally Posted by pac.attack76 View Post
So I need to remove that fuse? Pin 5 is G1 right?
Yes on both.
When troubleshooting red plating, it's best to avoid running the circuit until the problem is solved, but if you need to run the circuit to make voltage and waveform measurements, then running without the cathode fuse is one way to prevent the plate from dissipating too many watts and weakening it. Removing the plate cap is another, but sometimes the lead drifts back to the tube and arcs.
Pin 5 is the first grid on most typical Zenith outputs like the 6LF6, but if you have a different output (not familiar with your model number), then you can look up the datasheet for the tube on line and identify the first grid.
John
