Old 05-21-2024, 04:16 PM
pac.attack76's Avatar
Stuck in the past
Zenith color console 14B9C50
Just got this one the other day from a friend. Turns on with sound and backlit channel selector but no video. What year would this one be? I figured somewhere between 68 and 72. If more pics are needed, lmk. Really want to see this one working.
File Type: jpg IMG_20240518_172627813_BURST000_COVER.jpg (143.8 KB, 64 views)
Genesis does what Nintendon't
Old 05-21-2024, 05:56 PM
B is 1972. Does it have raster?
Old 05-21-2024, 06:05 PM
Stuck in the past
Ok, thanks. Nope, nothing. Just the heater.
Old 05-21-2024, 06:25 PM
Don't run it for more than a minute like that. Check grid voltage on the horizontal output. Should be around -75V. If not your horizontal oscillator isn't running.
Old 05-21-2024, 07:01 PM
Stuck in the past
Isn't that the 6U10 tube? Set needs to be on or just plugged in?
Old 05-21-2024, 07:11 PM
Clean set. Tubes I can see are OEM. White or yellow = OEM, red labeled are replacements.
Hoz out usually fused with a Bel-Fuse Those 2 green squares are examples
Hoz will be black & say 500-1. Center rear on top or under chassis IF it uses one.
Careful of that HO tube, VERY expensive !
Zeno
Old 05-21-2024, 07:24 PM
Stuck in the past
Zeno
I don't recall seeing a fuse for that but I'll get in there tomorrow and look.
Old 05-21-2024, 09:28 PM
Zenith bel fuses are plastic rectangles.
Old 05-21-2024, 09:29 PM
Stuck in the past
Yeah I seen the two green ones but didn't notice any others.
Old 05-23-2024, 05:13 PM
Stuck in the past
I'm gonna get in there this evening and look to see if there is a fuse near the oscillator. Also I'll test for reading. Where should I put my leads? Just wanna make sure I get it right.
Old 05-25-2024, 06:12 PM
By convention use the steel chassis for ground ( - or black lead).
Newer sets may have several ground points. Voltage is measured
at the Hoz out tube G-1 (6LB6 ? ). If the voltage in NOT very
negative ( @ -70 to - 90 VDC ) it will eat the H out & in some cases
melt it ! So keep testing under 1 mn til you get a raster.
You can measure from the top, you just need to count the pins CCW.
Pin out is on any data sheet for the tube.
Zeno
Old 05-25-2024, 06:22 PM
Stuck in the past
Zeno
Ahh ok, number 5. I'll get in there tomorrow and see what I get. I'll check for that belfuse as well
Old 05-26-2024, 11:20 AM
Stuck in the past
One pic shows a fuse nearby. I couldn't get a reading. Did I do it right?
Old 05-26-2024, 02:52 PM
Looks right. See if the fuse is open.It goes between the hoz out cathode & GND.
If blown you can just jump it out for a FAST check, < 1mn.
Things can get complex now so take it slow, one thing at a time. NO shotguns !
Zeno
Old 05-26-2024, 05:57 PM
Stuck in the past
Zeno
If I did it right on meter, it showed open. I'll jump it for a few secs. If jumping it, what will it do? Work normally or?
