Old 04-10-2023, 10:39 AM
Chris K Chris K is offline
I am atomic! Lol. You can edit your posts if you want to there should be an edit button next to quote if you are reading this via a web browser.
It's encouraging that it was an external generator, but you can still get same false reassurance from an external generator if both the generator and scope have 3 prong power cords...Most test equipment that have 3 prong power tie the signal negative/ground to building ground and test equipment plugged into the same outlet can sometimes use that in lieu of the signal cable ground when it goes open.
They are both run off USB cables off non-grounded plug in transformer chargers...thank God
