Old 11-27-2022, 04:40 PM
trinescope trinescope is offline
Rusty CTC-22 resurrection
I got this a few months ago, was a victim of long term outdoor storage and the chassis got pretty rusty as a result. I stripped it down completely to clean and zinc plate the pieces so they would look good again. I had to replace the damper diode (of course) and so far borrowed the tubes out of my other CTC-22 for testing, since the ones in this set were either missing or had white getters. All the FP electrolytic cans had to be restuffed. CRT tested nice and strong, so I was encouraged to do an extensive restoration like this.
Erich Loepke
Old 11-27-2022, 06:36 PM
cj_reha's Avatar
cj_reha cj_reha is offline
Well damn! That puts the restoration work I'm doing on my CTC22 to shame! And I thought I was nuts for just pulling the boards individually...
That really looks great. How'd you remove the rust on your chassis? Mine looks similar and I was planning on simply leaving it as-is and keeping it dry stored to minimize rust spread. But if there's a good way to get it off without essentially turning the set into a build-it-yourself kit I'd love to know!
When you lower your standards, you set a new standard!
ISO: Mitsubishi 6CT-338, Sony Chromatron 19C70/100, Yaou "Colornetron" GTC-9, etc...
Old 11-27-2022, 06:43 PM
On this one, I had to take it all the way apart, because I had to do electrolysis on the parts, as well as bead blast some of the pieces, and acid dip then plate in a plating bath.
Erich Loepke
Old 11-28-2022, 09:31 AM
WOW you deserve credit. If I saw that pile of parts I would never
think it would work again. If it came in the shop I would have
shown you the door.
Well done
Zeno
Old 11-29-2022, 02:55 PM
mbates14 mbates14 is offline
Boiling Springs moment
Old 12-05-2022, 07:57 PM
This has to be the definition of a labor of love. Fantatic work. The picture looks great.
You should start a thread on your plating process, I think there are many of us here that would be interested.
Old 12-28-2022, 11:50 PM
LukeSimon LukeSimon is offline
Incredible! Can you post a video of the process?
