Old 11-12-2022, 11:47 AM
Moose Moose is offline
Arrow Question about back panel of RCA FGR2020W ColorTrak 2000
Hello,
I'm a bit of a novice when it comes to these old CRT's. Can someone explain to me what all these do exactly?
This one says " Audio Output Dual Dimension" I'd like to know if I can just connect standard RCA Audio Connectors to it or do I need a special connector?
This is the back panel of RCA FGR2020W / RCA Colortrak 2000
Can someone explain what all these do exactly? A/C Switch due? what adjusting the BIAS and Drive does? Service Switch does?
Thanks for any help.
Old 11-12-2022, 01:51 PM
The RCA jacks just plug into the AUX on a stereo. It probably had
fake stereo hence the name.
Cant quite read the others but at least 5 of them are related to setting the picture "gray scale" to get a good B&W pix.
You NEED a good B&W pix to get a good color pix !
If you can find a manual on line it will give the procedure.
Old 11-12-2022, 05:15 PM
Popester's Avatar
Popester Popester is offline
The service switch collapse’s the vertical sweep. It is used to set up proper grey scale adjustments. Unless you have a manual and tv experience I would recommend leaving them alone. The audio out RCA are just standard RCA jacks. No special cable is needed.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 11-12-2022, 05:19 PM
Popester's Avatar
Not sure about the AC switch, but if the set was a remote set the AC switch might completely kill power to the tv. Remote sets always have some power running the remote circuitry. The switch would kill all circuits if off. I’m just guessing as I don’t really know what the switch does on a ColorTrak.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 11-12-2022, 09:43 PM
damen's Avatar
damen damen is offline
AC stood for "automatic color". Sort of an auto tint and color intensity mode. I always left them turned off.
Old 11-13-2022, 12:15 PM
On the Zenith and RCA remote sets of the tube era the remote switch wouldn't disable the TV power, it would disable power to the remote reciever and make it so you could only turn the set on and off with the front panel power control...That may have changed in the solid state era, but I suspect it didn't as installing a kill switch for the entire set on the back seems pointless.
Old 11-18-2022, 11:21 AM
Popester's Avatar
I had a Sony KV-2648R that had a master power switch that I would turn off when gone on vacation. It would kill all internal power to the tv. I think some remote brands even had a switch labeled “vacation”.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 11-18-2022, 03:04 PM
Yes but I only remember them in the mid 70's on JA sets.
It would kill everything. Useful so that it wont get hit by lightning &
no dog tags etc would trigger the set on. I remember them on Zenith
remotes for a few yrs but they were not right on the AC input
like the JA sets. Zeniths killed the remote rec. but not the instant on
for the few years they used it on SS sets.
Old 11-18-2022, 06:52 PM
nasadowsk's Avatar
Damn does run fast…
Didn’t the Colortrak (2000?) use I/Q demods, like the CTC-2 did?
Old 11-19-2022, 02:31 PM
Don't know which chassis the Colortrak 200 used, but here's some enlightenment on the solid state I/Q demods (my post #10):
http://videokarma.org/showthread.php...q+demodulation
