Old 10-07-2022, 07:18 PM
liammc00's Avatar
liammc00 liammc00 is offline
real TVs have a CRT
It being a funai means the mode switch is probably dirty and you don't have to do any soldering work to get to it. You just need to unscrew the mechanism from the top and two screws from underneath the chassis. Then left up the chassis a little bit to get to the mode switch. Another thing that can cause trouble are the tape end sensors the can sometimes get cold solder joints. Funai VCRs from 1992 and newer are very poorly made in my opinion and when a VCR powers off it's normally do to with mechanism and on funai's always start with mode switch. There are YouTube videos on getting to the mode switch on funai VCRs from that time poried.
Old 10-07-2022, 07:23 PM
ESigma25 ESigma25 is offline
Originally Posted by liammc00 View Post
It being a funai means the mode switch is probably dirty and you don't have to do any soldering work to get to it. You just need to unscrew the mechanism from the top and two screws from underneath the chassis. Then left up the chassis a little bit to get to the mode switch. Another thing that can cause trouble are the tape end sensors the can sometimes get cold solder joints and I have seen were one of them has gone bad. I have had the belt There are YouTube videos on getting to the mode switch on funai VCRs from that time poried.
Hmm, I had pulled out every screw I could find but the mechanism wasn't lifting up at all.
Old 10-07-2022, 07:31 PM
liammc00's Avatar
real TVs have a CRT
There hidden under the ribbon cables on the back of the PCB.
Old 10-08-2022, 10:35 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
The shop I put in 25 years at was a Funai authorized service center. I fixed many of those. One very common problem was the LED under the mechanism and the optical prism that went up into the cassette when loaded and directed the light to the takeup and end sensors and also the reel sensors. There was a kit for that which included the sensor phototransistors but I never found one of those bad, just the LED. The prism would sometimes warp out of shape, or get broken off when someone would try to remove a tape that wouldn't eject
