Old 12-09-2021, 05:52 PM
What everyone else says. Look to see if there is any electolyte on the board.
If there is any of the juice on there you'll have to clean it all off or it'll keep corroding and flush it out well under all the parts.
There's likely a bunch of electrlytics that have failed or are failing though.
What I see is it has low video gain, and also the vertical bars plus random flickering.
Is there any signs that it's ever been dropped? (Eg. Ding or scuff marks in the plastics) Those bigger camcorders were sometimes toast if they ever got dropped.
Does the picture change it you tap on the case?
Also will it play a prerecorded tape from another machine or a VCR and is it viewable on the viewfinder?
Also if you are running it on the power supply check to see that there isn't a bunch of noise coming in from bad filters in the AC supply.
