Old 03-15-2020, 11:16 PM
BandDirector
Guest
Posts: n/a
On sets where the IF stages are hand wired disturbing the lead dress can ruin the alignment which is not something you want to mess up.
It might be a good idea to find a 5 tube AM radio and make that your first project. The average monochrome TV is 5x as complex as an AM radio but uses similar parts so if you make a mistake Tracing it down from the schematic is much less difficult.
Phill's old radios on the internet has a lot of good beginner info and detailed write ups with pictures of TV and radio restorations he has done.
The original trans is probably shot, but it might not be. If the B+ line in that set has a hard short on it (say from a shorted original lytic cap) and you didn't pull out the 5U4 before power up the trans could just be complaining of the overload.... sometimes if you overload a transformer till it smokes but don't run it too long it will survive, but the odds of that are not high.
Good luck on your project.
Thanks! I think the transformer itself is shot, the inside (if you look at some of the links above you can see it) has burned more often than just my testing it about 5 times.
