#31
This is interesting. I found that the color is much more likely to fail when the digital converter box is outputting a garbled, digitized signal than when it is outputting a clean signal. That's not saying it's guaranteed, but that is a phenomenon I have noticed with this set.
#32
It's a Magnavox from 2009 I found at at estate sale. I really don't like it, because I can only pick up one or two channels clearly, no matter which antenna I use.
Update - I swapped out the Magnavox converter box with the Zenith converter box in the other room. Now, the color does not fail, and I can get all the channels very clearly. If anybody remembers back last December, when I got DirecTV, a few of my TV's at that location did not take kindly to to the new source. A few of them had color problems very similar to this where the color would vanish completely, or they would start barberpoling. I think this TV's chroma circuit is just extremely sensitive to fluctuation from the video source. Last edited by TUD1; 08-29-2017 at 12:37 PM. |
#34
And this might be a good time to swap out the 6GH8s for known good NOS tubes.
![]() jr |
#35
I wonder what would happen if I put a 6KE8 in the color oscillator circuit, instead of a 6GH8, if that would help keep it from having these issues?
#36
If changing the source fixed it, it's not likely a color oscillator problem, but a color phase lock or color killer issue. (Just my 2 cents worth. Anything is possible.) Note, in some sets, if the color oscillator dies, the screen gets a greenish color balance. You didn't mention anything like that. You can try pulling the oscillator tube to see what the symptoms are for future reference.
#37
There were a few mylar? caps in these Maggies in either
the burst or 3.58 osc that went BUT IIRC it gave bad tint range or barber pole color. For now turn the color killer off & be sure the tuner isnt drifting. Also sometimes there are 2 AFT switches. One often part of the auto color AKA brownilator & a separate one. Both have to be OFF to properly fine tune the station. To test for drift turn all AFT OFF then FT the set so you still get the channel but it starts to just get wormy & bendy. Watch it like that for a few hrs & see if it changes. You can also get AFT drift but its rare. Just leave the aft OFF to fix that. For a source IF YOU DARE get a low power (10W) translator for a blank channel. If you are high up it will cover your town & much fatherLOS. 73 Zeno ![]() LFOD ! |
#38
I've sat and watched it with the DVD player for about 2 hours now, and I haven't had any problems.
#39
I would pull up a chair and put on a classic TV show from the 1970's and watch it for hours . |
#40
Try again...
#41
Thats great! |
#42
Resolder ALL the ground stakes for the chroma board. ALL of them. They can cause all kinds of intermittent problems.
#43
I did.
#44
Color's still working perfectly as of last night. Knock on wood. I think switching the converter box to the Zenith kind really helped.
#45
