DO NOT forget....all of the 19 and 20 inch MINI-NECK tubes... They do NOT hold up well at ALL...and will not take rejuv much better than a Trinitron. Now--the 13" mini-necks...not bad..pretty long-life..I suspect it is because of those tiny gun structures inside of that thin neck...
ALSO..those 1st gen GE inline larger than 10" tubes for the mid-late 70's...the one with the big neck line a portacolor tube...I have seen a LOT of bad ones of those in the day... And speaking of the Trinitron...not sure HOW they made them this way....but they just do NOT like to take rejuv...maybe for a few DAYS or so...then they look WORSE than before... |
I am keeping alive a 97 model 32" zenith console--with a GREAT tube. The cabinet is nice---and the elderly man does NOT want to get rid of it ? It makes me about $100 CLEAR..each time I work on it.. The last time it was just that little "pf cap" shorted and burned up off of the H-out. But I let him KNOW...if the tube WAS dying...I WOULD let him know....and for him to dump it. But that tube looks like NEW. I do NOT think the 32 and 35" Zenith tubes suffered like the smaller ones did. |
I don't think the 32" and 35" tubes were actually made by Zenith and that could be why they hold up so well. A friend had an early 31" Zenith digital system 3 (overpriced piece of junk) that had a Zenith-branded CRT in it; but, I never looked at it close enough to see if Zenith actually built the tube. Sometime in the mid '90's, it started going weak and I hit it with the rejuvenator. It lasted a few months and started going back down again.
Concerning Sony tubes, the earlier ones from the '70's and early '80's often won't rejuvenate at all and if they do, they won't stay up long. A few years ago, someone gave me a cosmetically mint condition 19" Sony from the early '80's (the varactor tuned model with the vertical row of buttons and a plastic woodgrain cabinet). The picture was green, with zero red and zero blue. On the tester, the green tested strong; but, the other two guns were totally dead and would not rejuvenate. I ended up junking the set. I've rejuvenated some of the later Sony tubes that held up for a little while; but, not as long as other tubes that I've hit. Concerning the later small neck color CRT's, the local hospital had 20" Magnavox sets in all the rooms and these used that type of CRT. The local parts house always kept that CRT in stock because they were constantly replacing CRT's in those sets. I think some of those sets are still in service; but, the last I heard, they are no longer repairing them. When they fail, they are being replaced with flatscreens.
http://www.youtube.com/user/radiotvphononut |
It seems like the large screen Zenith B&W tubes from the '60's and '70's often got weak quickly. I think many of those tubes were actually made by Sylvania. I have a Zenith 14N22 B&W console from '69 and it's CRT is, fortunately, still very strong. I don't know if the tube in that set is a real Zenith tube or one sourced from somebody else. One day, I may open it and see what the EIA number is.
Alright here is what I think happened to Zenith crt quality. many years ago when i first joined videokarma, "it was only Audiokarma back then". A forum poster noticed that zenith crt failure was cause by the aquadag "conductive" coating of the crt flaking off of the inside of the crt and being accelerated by static charges toward the the cathodes causing the hard shorts which killed power supplies.
About that same time period the was a documentary made about the closing of the zenith plant on melrose and there were audio interviews with former workers reminisensing about there days making crts. One of the employees commented that there were chemicals used in cleaning parts "CRT shells?" that were not allowed by the epa? osha? anymore. anyone knows coating processes are highly dependant on the prep and cleaning of the surfaces. here is a link to the documentary called "Matter of Time- Zenith" https://www.youtube.com/watch?v=6RSEIa3TZ6k the comments from the former worker are at 5 min, 32 secs |
SO....basically the "greens " KILLED ZENITH? and the SHUTTLE? and who knows WHAT else ?!!
WHY...am I NOT surprised to learn this? Maybe...because up to THAT point...Zenith had GREAT CRT's and before THEN--(Chromacolor delta days) the VERY BEST CRT"s EVER made..So...SOMETHING had to change... ANOTHER case of another "DISprovement" from the greens--to a used-to-be GREAT product !!! |
My E48-2 Sylvania has its original dark matrix 25VFAP22 which responded very well to my Sencore's auto-restore. It's a high-hour set, lots of dirt inside when I got it and it has gone through at least two triplers.
I'd put the cutoff date for good Zenith CRT's at 1992, because I saw a Zenith with a 1992 manufacture date and its CRT was still good and strong.
And I had a 1998 Zenith A27a23w with a good CRT as well. Compare with a 1997 Hitachi that had a Zenith CRT, that CRT was awful. |
In the early 90s, Sony was making CRTS at the former VW plant in New Stanton, East of Pittsburgh. Between that and RCA's plant in Lancaster, many BPC sets lasted longer than ever. looking great
"When resistors increase in value, they're worthless" -Dave G |
