Old 12-14-2015, 06:49 PM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
Originally Posted by fixmeplease View Post
Success! I changed the electros, a reg cap and a resistor that were in areas I had to solder anyway, plus some tubes.
The bottom half is brighter than the top half (the picture was not moving when I took it). My brightness will go much higher when I turn that control. Volume sounds ok. I only ran it a couple minutes.
Will start recapping, but how do I get rid of the 2 parts on the screen? (There is a curtain reflection on the top half)
Also, can I safely pull the chassis back, laying it down, to get at the picture tube button hole to safely discharge it? Can anything on the chassis bite me when I do that? theres no other way to get at it as you can see.
Congrats fixmeplease ! .. now you need to continue.. ( for a better result, i would change all caps and resistor ( paper and wax if the TV has them..)Even if some caps look like good , sooner or later they will ... POUFFFF !
