Old 09-12-2015, 01:13 PM
jbivy jbivy is offline
complete novice
whats the shaft rod i need called?
So do you see how the potentiometer is round with one side ground off? I want to mount some knobs on a project (just for display, not connected to anything). They take that kind of shaft for them.
Do they sell 1/8" rod like this?
Or maybe some tiny cheap potentiometer with long shafts would work.
Any ideas?
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 09-12-2015, 03:38 PM
Could always get round shaft that diameter and grind/file a flat spot into the end.
Old 09-12-2015, 06:02 PM
I assume you need a knob to fit it.
Depends how long you need & if its US or Jap made.
Some 1960's Zeniths used fairly long knobs ( apx 2-4" )
that had a split shaft & wrapped with a spring that
you could put on many sized shafts.
In the good old days we had knob boxes. If someone came
in looking for a knob we would hand them the box & tell them to
take a few free. On top of that we also had 30-50 common
new knobs in stock. The knob box was more popular than the
tube tested especially on Saturdays. God I miss them days
I am sure many here have a knob box & can
help with a few knobs.
Old 09-12-2015, 08:13 PM
complete novice
ive already got the knobs. Thats why i specified 1/8th inch.
Im sitting a BPC inside an empty 50s tv cabinet. The chassis and crt were shot, so i sat a modern tv inside it. I just need to mount the knobs back on the tv case, so it will look stock from the outside.
I think ill just find some aluminum rod and grind it to fit.
Old 10-26-2015, 03:31 PM
Reece's Avatar
Reece Reece is offline
The pot you pictured, and most radio-TV knobs, are on 1/4" shafts, not 1/8". Take the knob to the hardware store. Look for long machine bolts with 1/4" shaft. You can cut the head and the threads off those and use the unthreaded portion: chuck in your vise and use a good new flat file to file the required flat for the knob. The store also may have plain 1/4" rod.
Reece
Old 10-26-2015, 05:31 PM
Findm-Keepm's Avatar
Followin' the Rules...
Shaft extender - that's what HH Smith, Keystone, and Clarostat called them back in the day.
I've robbed the Meccano erector sets for their 1/8" shafts to use on Oscopes - the diameter is perfect, and the shaft joiner/splice has two set screws.
Brian
USN RET 22YRS (Avionics/Cal)
