Old 09-30-2015, 09:57 AM
I assume you want to pull the chassis out ? Usually
you can flip it on edge & run it. Just dont put strain
on the wires. Can usually put a box behind the set
to rest it on. Alternitive is flip the whole set on its side
HV area down & you can run it & do tests. Sets with bottom
plates like Zeniths are almost always done that way.
Just remember the purity will be way off, thats normal.
One other important thing. Until you change the thermistor
JUMP IT OUT or the VDR will burn. They stink too !!!
On HV shocks be as careful as you wish. If you are
healthy it should not harm you but.......
I have got nailed many times by HV. Worse it did
was give me A-fibs for maybe 20 sec. a few times.
In fact if you already have A-fibs it may cure them if
the timing is right !
When they fix them they put a ground on your back
then on your chest. The machine has a sync curcuit &
at the right point SNAP ! And you are back to normal
rhythm often. You are asleep during it. I had it done
3 times.
