Old 09-22-2015, 07:40 PM
rca2000's Avatar
rca2000 rca2000 is offline
Latest thrift find...
I found this cute little 1965 model GE set at a thrift store a few days ago...
Set does NOT work, but all tubes light. All tubes except tuner are compactrons.
Hot chassis of course..and I normally do NOT like hot portable sets. But it just looked SO lonely sitting there.
Besides..the Pix tube tests like NEW--a 19VABP4 IIRC. ALL tests..cutoff, emissions and life.>ALL perfect. In FACT...tube tests good on emissions at 4.5 volts on fil !!
WIll VERY likely bring this 16 incher to the swap ,meet next week...
Old 09-22-2015, 09:06 PM
Worth more if it works. Probably just the 5.6 ohm & rectifier.
Old 09-22-2015, 10:19 PM
Findm-Keepm's Avatar
Followin' the Rules...
S-? Chassis - good sets. Back in the day, they were the sets in the Kitchen or a lucky kids' room. If the antenna rod was broken, we assumed the set was in the kids room...
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-22-2015, 10:20 PM
New math, or typo...
Brian
Old 09-22-2015, 10:22 PM
rca2000's Avatar
typo MEANT 16VABP4 !!
Old 09-22-2015, 11:53 PM
jbivy jbivy is offline
complete novice
good looking old set, nice find.
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 09-23-2015, 12:04 AM
rca2000's Avatar
THINK ,....it said "EA Chassis"..Mostly on a PCB, I think only 9 tubes, No HV cage to speak of..
Old 09-23-2015, 10:56 AM
A very common problem on those was the H osc. coil getting torn partway out of the board, due to someone jamming the back on without lining up the stem with the hole.
Old 09-23-2015, 10:59 AM
IIRC, that was the first GE set to use all Compactrons, except the tuner, of course. Of all the GE sets, I worked on, I never worked on one of those.
They named it the "Escort".
Old 09-23-2015, 11:05 AM
I always was very careful working on other's property.
I saw some careless tech's?, damage the CRT neck, by forcing the back on or off of a set.
Old 09-23-2015, 11:30 AM
rca2000's Avatar
That reminds me of when I guy who I knew years ago (he is DEAD now--from prescription drugs..)..was "working " on an IBM monitor I thnk...and he was having trouble getting the rear cover off. IIRC...It had some WEIRD tabs or something holding it together...and he was having trouble getting it off. So..he just decided to YANK it off..pulling it UP from the bottom...and OVER the neck of the tube...He tugged and grunted and THEN......HHHSSSSSSSS...came from the monitor !!
I could NOT help laughing.!! he just said...welll...it needs a PICTURE TUBE.. I said..Yeah...it does NOW "!!
Old 09-23-2015, 05:35 PM
Broken ant. could as easily be a kitchen set. I've seen 2-3 antennas die at the hands of my mom...
Old 09-23-2015, 06:10 PM
GE used that same basic cabinet design for years. I have a late '70's 15" solid state GE, using the XB chassis, that's in that same basic style cabinet.
Old 09-23-2015, 08:34 PM
rca2000's Avatar
BOTH of my antennas are INTACT on this set....
Old 09-23-2015, 08:37 PM
probably on cable?
Brian
