#61
The later models used a 21YP4. The screen curvature looks like a Y.
#62
Still the same heater voltage, and I'm all sorts of confused. I'll pull the 5U4 and power it up again and see what I see.
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
#63
Aw frig. I didn't look at the chassis too closely. I kind of figured I'd run into seleniums the size of toasters in this damn thing. After all, Raytheon wasn't exactly known for a quality product in the TV realm.
One of those things that I knew would be a PITA to restore, but figured that if I didn't do it nobody else would, and what the heck, at least I had a starting point. This is the screen shot I had from last power up. Potential is there, anyway....but this one might wait for a while.
#65
Well, it does have a 5U4, so nyah
![]() This picture tube issue is weird. With a "remove shorts" procedure, the tube tests into the good range, but the H-K leakage pegs the needle. Not sure what type of picture that'll end up giving.....? Now here's a thought. The 21FP4 uses electrostatic focus. I believe I can use a 21EP4 which uses magnetic focus. I have a good 21EP4. Just have to rig up a focus magnet assembly.
#66
Could also grab an isolation 'booster' and skip the modification.
#67
I've never ran across a Raytheon with that control panel, that had a full transformer and 5U4 chassis.
#68
Yup! Here's a shot of the nasty dirty chassis.....
#69
I didn't think they built that chassis in a 21" model. It looks like there's mounting holes, for a PM focus unit.
#70
I split this thread off into another thread about the Raytheon just to keep things organized, we can pick up on it there
