Old 02-14-2015, 09:04 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
Here is a picture of the single vertical and horizontal convergence pattern that had so much ringing when I first powered up the set. The color would initially work and then fade away when I first powered on the set after the recap. I found that the second chroma output was fading. It is gain controlled using a bias from the color killer modulated by Zeniths Automatic Color Control. For now I cheated and just put a resistor in parallel with part of the bias filtering to increase the gain to keep the color working. It still kills the color on black and white video and seems to work fine otherwise. Here are some pictures of video through the tuner. I may make one more pass through the IF alignment and then do the audio alignment. The audio has a little distortion in it at the moment.
File Type: jpg After-Goodman-Alignment-and-DelayLine-Pot.jpg (128.6 KB, 39 views)
