Old 06-26-2013, 05:30 PM
jshtulman1 jshtulman1 is offline
ID the set in this craigs post?
I'm looking for a nice vintage color tv, preferably a Zenith, to place in my room and be one of the main sets I use. Can someone please identfiy this particular Zenith? Looks like a late 60's model. Maybe a 66? Since I usually only collect pre-1963, I'm not well versed in later sets. Also, how was the quality of sets aat this time? I know that foreign sets started to flood the market by around 1974.
http://sfbay.craigslist.org/sby/hsh/3869053435.html
Old 06-26-2013, 07:06 PM
Looks like a 1966-1970 model. The control panel looks like no Zenith I'm familiar with. If the tuning knobs are not missing then it might be a Space Command remote control equipped model.
Having had at least 9 different tube Zeniths from 1950 to 1971(4 being color) and two delta gun color SS sets I've come to form the opinion that nearly all the tube Zeniths up through the first few SS models were very good quality.
Old 06-26-2013, 08:10 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
You can't beat nearly any tube type Zenith for quality. I have had a few Zenith sets over the years and they were all good. The build quality is excellent on Zenith sets in general and they are the perfect daily use set. The color ones are a bit more maintenance intensive but well worth having. If you get that set, the hardest job will be removing the cataract from the CRT but it can be done.
Old 06-27-2013, 08:06 AM
65 or 66 would be about right. Most survivors are the bigger
sets with bass & treble controls. See ad.
https://www.youtube.com/watch?v=sIefAOli1QY
This one is from the low end. The knobset looks like the
ones they used on the first 14" color. Chassis is probably
near the same as the big set.
Old 06-28-2013, 10:53 PM
John Adams's Avatar
John Adams John Adams is offline
I worked for a Zenith dealer from 1963 thru early 1970 and I, also, say The control panel looks like no Zenith I'm familiar with. The back should have a date on it.
2 Working Zeniths and one on the bench. Into electronics since the days of Earl "Madman" Muntz..Worked 8 years for a Zenith dealer in NW Arkansas.
Old 06-29-2013, 08:06 AM
This set is actually a 1968 model, and yes, quite an unusual control panel. This set would have a 20Y1C38 chassis. The CRT is NOT original. If the original CRT were present, it would have a non-reflective bonded lens (and most likely have green halo too).
Too bad that rear right leg was snapped off....
Old 06-29-2013, 09:24 AM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
Run, do not walk. Your a fool if u do not buy this for $30.
