Old 06-14-2013, 08:54 AM
VintagePC's Avatar
Tube bug got me 05/2010
Transformer AC doubler question
Just something odd I was curious about and thought someone here would know for sure.
Can one make an AC voltage doubler using only a center tapped transformer? It seems logical that it would work if connected like an autotransformer with no secondary - e.g. 120V AC to center tap and one leg, then getting 240v AC from one leg to the remaining leg.
Are there any problems with this method? I've been searching online and have found very little, perhaps because I'm using the wrong keywords, or because there's a reason this isn't done?
Does that still follow the standard inverse power calculation for a transformer (2x voltage = 1/2x current) or is it different because there's no secondary in use and the full current going in comes out?
I realize there's probably a simple answer but I've been wondering about this for so long that I'm starting to overthink it. :/
Old 06-14-2013, 09:40 AM
dtvmcdonald's Avatar
The answers are yes and yes.
Old 06-15-2013, 07:16 AM
earlyfilm's Avatar
Eternal Member
Works fine, as long as you you stay within the voltage and current ratings of the transformer.
The problem is the current ratings were probably not determined for this off-spec use, so verify that the transformer stays at a reasonable temperature.
James
Old 06-15-2013, 12:16 PM
VintagePC's Avatar
James
Thanks for all the input.
The final application wouldn't draw much current at all, and I have a fairly bulky 2-3A transformer I intend to use.
